will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg?
New User
AEM doesn't have a fuel rail for a 92 integra, but I've heard the 3rd gen fuel rail would fit. I've looked at a 94 integra and it looks very similar to my 92, but there could be minor differences. Can anyone confirm that they are the same?
Re: will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg? (Brian_92GSR)
Re: will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg? (91civic)
they fit all b series motors last time i checked.
yours is a b series. so it will fit.
The only difference is where they position the fuel inlet banjo bolt. The 3rd gen teg has the fuel filter higher up on the firewall.
Dustin
Dustin
Re: will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg? (dustin)
hey brian did you cacel your order?
I told you that there should be no reason that it wouldn't work for any B series Intake Manifold.
New User
Alright, thanks for confirming this. I also need to get some AN fittings for hooking the Paxton FPR up. Are these parts that local stores should have?
Local stores probably do not carry them, but http://www.bakerprecision.com and http://www.anplumbing.com do (expensive though).
I have had very good experiences with the above two vendors.
Dustin
Dustin
New User
Do you know which fitting I would need to hook the fuel return line up to the FPR (which is AN -6)? I've figured out everything else but I'm not positive on this one. BTW, I'm using anplumbing.com
JG90CRX-Si
02-03-2005 06:28 PM
