AN fitting problem on garret T3/t4 oe
Old May 6, 2003 | 03:05 PM
BlackB18CTeg's Avatar
Default AN fitting problem on garret T3/t4 oe
Aight, well I dunno how many you have this problem. But When I install the an adapter onto the flange, and then install the flange to the turbo and attach the 90 degree AN fitting, the Manifold will not bolt on to the turbo. THe AN fitting gets in tbe way . I have noticed that the AN adapter does not screw all the way into the flange. Should it? It gets REALLY TIGHT and I cant screw any farther. Any help will be appreciated. THank you.
Forgot to mention, this is the max rev kit.
FlyNLow1987
Mar 8, 2014 05:40 AM
blackpearlcivic
Welding / Fabrication
10
Jul 5, 2007 04:04 AM
BOOSTEDk24a4
Jun 25, 2007 09:51 AM
spoolingb20
Oct 3, 2006 05:17 AM
DavidR
Sep 2, 2005 01:26 PM
