Turbo Manifold Flange
Who is Mr Robot?
Re: Turbo Manifold Flange
yep it's Chryslers goofy t3 based turbine housing. I never understand why OEM companies have to modify something that already works fine
as stated above there's enough material to drill it for a t3 flange, IIRC there are two holes that already line up with a standard t3 flange.
DO IT ON ALL FOURS
Around what situation exactly? If you mean converting it to a regular T3 flange either change the housing or drill the T3 pattern in the flange. I thought that was pretty obvious.
Yeah I came across those but I thought the same thing too. I also didn't know if it would have a effect in performance. I've given it some thought and I'm thinking about just ordering a new housing. That way it will bolt right up and I can also get rid of that 5 bolt flange as well. Thanks everyone, your help is greatly appreciated.
ExploitedRacing-HR
Welding / Fabrication
22
12-06-2004 04:21 PM
