first timer
Old Dec 6, 2007 | 08:53 AM
KleenL's Avatar
Default first timer
this is my first time building an import and also my first time with any kind of boost. well i jumped into buying parts as they came along without doing any kind of research. so far i have aquired 2 h22's one stock jdm and one sleeved block. right now i'm running the stock h22 with no boost and building the sleeved block for boost. i plan on boosting the stock h22 to get a feel for everything before i go big. well i have a few questions. first of all it looks like i made a poor purchase. i got one of those ebay t70's. my main question is if i build my setup with the turbo i have how much will i have to change to replace the turbo (manifold, downpipe, retune, etc...???). also i would like to know where i can get info on turbo sizes and performance. everything i read about them seems like another language to me right now. any help would be greatly appreciated.
Old Dec 6, 2007 | 09:08 AM
bigbadboy's Avatar
just get everything your going to use in the future now. cause if you have to get it all twice its gonna get way too expensive. just try to sell that turbo and get a new turbo that will suite your HP goals then pick a manifold and go from there.
Old Dec 6, 2007 | 09:17 AM
DA_HONDA_BOY's Avatar
Default Re: (bigbadboy)
what kind of car it's going in
and whats your power gol
Old Dec 6, 2007 | 09:22 AM
KleenL's Avatar
Default Re: (DA_HONDA_BOY)
92 prelude si and my horse power goals for the sleeved setup is around 450 or 500
Old Dec 6, 2007 | 09:30 AM
KleenL's Avatar
Default Re: (KleenL)
i really dont understand what the diffrent measurements of the turbo mean in terms of spooling, fit, and horsepower so i'm having trouble trying to figure out what turbo is right for me. is there anywhere that breaks this stuff down in layman's terms so i can make somewhat of an educated decision on my own. people have told me what turbo is good for me but i would like to know for myself what i'm getting into.
Old Dec 6, 2007 | 09:32 AM
i'll use a gt35r turbo for that goal but thats just me
and forget about ebay!! do it right the first time
Old Dec 6, 2007 | 09:34 AM
on that motor i seen a gt35r spool around 4000-5500rpm for full boost
Old Dec 6, 2007 | 11:41 AM
KleenL's Avatar
are you using a h22, is it sleeved, and how much boost, horsepower are you at
Old Dec 6, 2007 | 06:12 PM
im not a h22 guy but a gt35r will good for your power goal
i seen a h22 make 700+whp at 34psi
Old Dec 6, 2007 | 06:42 PM
SteamedRice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KleenL &raquo;</TD></TR><TR><TD CLASS="quote">i really dont understand what the diffrent measurements of the turbo mean in terms of spooling, fit, and horsepower so i'm having trouble trying to figure out what turbo is right for me. is there anywhere that breaks this stuff down in layman's terms so i can make somewhat of an educated decision on my own. people have told me what turbo is good for me but i would like to know for myself what i'm getting into.</TD></TR></TABLE>
http://www.turbobygarrett.com/....html
hope that helps
Old Dec 6, 2007 | 10:27 PM
KleenL's Avatar
Default Re: (SteamedRice)
that is what i was looking for thanks
Old Dec 7, 2007 | 05:59 PM
it helped me, i also read corky bell's maximum boost. hell, with that book you can be a freakin guru (but i'm still a noob, it's got everything as far as principles and building are concerned.
Old Dec 7, 2007 | 08:35 PM
HiProfile's Avatar
a 60-1 compressor would do what you want, and not be very laggy with the right T3 turbine. A stage3 .63 AR will make 450whp on a B18, but you could probably get away with a .82 AR if its not going to be on the road every day. If you choose to spend 2x on a turbo, a GT35R is a similar turbo as far as power.
As far as replacing everything, it depends. If its a straight T70, as in T4 turbine housing, it will cost as much as you'd spend on journal bearing turbo to retrofit a different one.
You'd do best to sell the T70, pick your final turbo, then buy that or a cheaper, smaller version with the same turbine housing. It just happens that a GT35R can have the same turbine housing as a 57trim t3/t04e, which would be perfect for a stock 2.2L motor.
93 Eg Couper
May 20, 2009 11:51 PM
Slomies
Dec 24, 2005 07:05 PM
95accordh22a
Jun 8, 2005 06:17 AM
vtec92lude
Jan 4, 2005 08:13 PM
11sh22a
Jun 27, 2004 01:21 PM
