First pull on turbo setup (video inside)
Old Jul 1, 2013 | 03:09 PM
DJ 2501's Avatar
Default First pull on turbo setup (video inside)
Stock b18b ls with arps
dsm 450's
neptune
precision ar .63 hot .60 trim cold t3
2.5 downpipe and exhaust
7psi
Thing doesn't spool til 4k.
In this pull was not all the way on the throttle and was shifting early.
Tell me what you think, should it seem more responsive than this or is this normal? I'm excited
Old Jul 1, 2013 | 03:20 PM
TheShodan's Avatar
Moderator
Default Re: First pull on turbo setup (video inside)
Seems normal. wheel measurements of the turbo would be nice just for verification, but they seem small enough for just your needs. Just enjoy it already. No more e-pinions. just drive.
Old Jul 1, 2013 | 06:59 PM
DJ 2501's Avatar
It seems like it's not pulling like it should. Comparing my pull to similar setups and the accel doesn't seem right. Going to check for boost leaks tomorrow.
Old Jul 1, 2013 | 07:49 PM
Hidenplanvew's Avatar
Same setups from your location, there are alot of things that can change outputs. It never hurts to look for leaks and such but it looks normal to me...
Old Jul 2, 2013 | 12:12 AM
yungkhmer's Avatar
what turbo is that exactly?
Old Jul 2, 2013 | 05:37 AM
DJ 2501's Avatar
Precision 3431e .60 trim
Old Jul 2, 2013 | 08:30 AM
DJ 2501's Avatar
Ok I adjusted the bov, it appeared to be exhaling air at the slightest rpms while idle. Less than 3k and it was spitting air out.
Here's a clip of the datalog
and a video
Old Jul 2, 2013 | 08:09 PM
yungkhmer's Avatar
i thought so, i just wanted to double check. i have the exact turbo, i love it so far. cant wait to push it.
Old Jul 14, 2013 | 01:01 PM
DJ 2501's Avatar
Ok got it all street tuned on 7 psi. Here's a pull launching with antilag building 2-3psi before launch and preloading the axles.
Old Jul 14, 2013 | 02:25 PM
TheShodan's Avatar
Moderator
Again, sounds normal.. And it's ok for the BOV to do that. Better that it not being able to release as needed. It's only 7psi.. It isn't broken so pleased don't do anything worse like try to fix it.
Sounds fine.. We're you expecting something else? (Curious)
Old Jul 14, 2013 | 03:07 PM
Turbo-LS's Avatar
Mac whats that turbo equal to a 50 trim? in any event something of that size on a mear 7 pounds of boost that looks and sounds spot on for a b18b. it will wake up a bit more around 12 pounds when the turbo gets into its efficiency range more.
Old Jul 14, 2013 | 03:29 PM
DJ 2501's Avatar
Yeah I'm happy with where it's at now and the street tune is pretty solid. Still need to get to a dyno and try for 280hp. Not sure where it's at now but I know it's not close to that.
Old Jul 14, 2013 | 03:38 PM
Turbo-LS's Avatar
Prob 200-225
Old Jul 14, 2013 | 03:43 PM
TheShodan's Avatar
Moderator
Yep. You are spot on , my friend. The SC3431 is 54mm ind/ 75mm exd (aka "50 trim") using a Precision .60A/R compressor cover and stage III turbine wheel good to about 45-47lbs/min. It'll be more responsive as boost pressure increases.
Old Jul 14, 2013 | 03:52 PM
NZXTInerTia's Avatar
That seemed awfully slow for a turbocharged setup. Check for leaks, potentially your turbo is just plain too small for your needs.
komat
Aug 9, 2007 02:07 PM
b18bEKcoupe
Jun 15, 2007 12:36 PM
TurboMiata
May 15, 2005 04:41 AM
Charbon Sty
Jun 23, 2004 09:53 PM
IggDawg
Oct 2, 2003 09:52 PM
