First Gear boost??
Old May 14, 2006 | 12:27 PM
PearlWhiteAccord's Avatar
Default First Gear boost??
just got my car running and want to know how come i dont hit boost on 1st gear, yet i hit boost on 2-4?? Just curious..
also, i have weird idle going from 1k -1.2k and after a few mins it would go back to normal ~850rpm
This is a d16z6 w/ chipped ecu running only 5psi on crome and stock everything..
Old May 14, 2006 | 12:28 PM
Soccerking3000's Avatar
Default Re: First Gear boost?? (PearlWhiteAccord)
the idle is probably from the IACV, try cleaning it out, as for boost, what turbo are you running? i have a 57 trim t3/t04e and i only get around 9 psi in first... you should definately have some pressure, make sure there arent any leaks
Old May 14, 2006 | 02:20 PM
Default Re: First Gear boost?? (Soccerking3000)
Apexi kit only running 5psi boost w/ stock injectors, it idles fine after a few mins in neutral, and idles fine b4 i installed turbo...
Old May 14, 2006 | 02:50 PM
Da K00l Aid Mayun's Avatar
its probably because you are only running 5psi
I run 15psi every day and I get only a portion of that in first gear
Old May 14, 2006 | 02:52 PM
portenio78's Avatar
Default Re: First Gear boost?? (Da K00l Aid Mayun)
I used to have the Apexi kit, check everything over cuz I would hit 10 psi in first by 3500 rpm.
Old May 14, 2006 | 02:58 PM
Default Re: First Gear boost?? (portenio78)
oh, but u running 10 psi, i am set at 5psi max since my stock injectors are still in there...
i think the previous guy is rite, i just talked to someone and he is set at 5psi and doesnt hit full boost till 6k rpm on first gear...
Old May 14, 2006 | 03:28 PM
portenio78's Avatar
Wrong, When I first got the Apexi kit I too ran 5 psi and it hit it by 3000 rpm. That is a very tiny BB turbo and it spools super fast. Check everything over brother.
Old May 14, 2006 | 03:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by portenio78 &raquo;</TD></TR><TR><TD CLASS="quote">Wrong, When I first got the Apexi kit I too ran 5 psi and it hit it by 3000 rpm. That is a very tiny BB turbo and it spools super fast. Check everything over brother. </TD></TR></TABLE>
i agree with that turbo you shouldnt have any issue hitting full boost in first...
DriveSlowHomie
Sep 27, 2005 05:54 AM
S2KP
Jul 28, 2004 06:36 AM
PrecisionH23a
Oct 16, 2003 11:01 PM
integranator
May 1, 2003 05:27 PM
ludelvr
Jun 24, 2002 12:31 AM
