dammit....CEL codes after boost...
Old Sep 29, 2003 | 07:49 PM
chinners10's Avatar
Default dammit....CEL codes after boost...
Im getting codes for my MAP sensor and my IAC sensor.... i have the missing link...and im only running 5 psi for now...why would my map sensor go bad? and what would make my IAC sensor go bad also?? any one with ideas?? thanks
Old Sep 29, 2003 | 08:04 PM
Rakka's Avatar
Default Re: dammit....CEL codes after boost... (cxhatch02)
if your iacv was bad, your car wouldnt idle. if your check valve was doing its job, you wouldnt get a CEL with boost. Try uberdata, won throw cel's with boost and will make your car run much better than the fmu
Old Sep 29, 2003 | 08:18 PM
bottlefedb18c1's Avatar
Default Re: dammit....CEL codes after boost... (Rakka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rakka &raquo;</TD></TR><TR><TD CLASS="quote">if your iacv was bad, your car wouldnt idle. if your check valve was doing its job, you wouldnt get a CEL with boost. Try uberdata, won throw cel's with boost and will make your car run much better than the fmu </TD></TR></TABLE>
but how much boost can you run with the uberdata?
ls19integra95
Jan 21, 2008 06:52 PM
kell211
Oct 8, 2003 07:00 PM
luderone
Sep 30, 2003 09:14 AM
ID_ten_T
Jun 9, 2003 03:06 PM
zojirushi
Dec 22, 2002 08:15 AM
