Finished install...bogging like hell and overheating!!
Old Aug 30, 2005 | 05:39 PM
TyeJ23's Avatar
Default Finished install...bogging like hell and overheating!!
Ok we finished the install today on my GSR. Full Race stage 1. It's running on the stock ECU right now with stock injectors...NO BOOST...it gets tuned on the 8th. NOW...on the way home it was bogging like crazy...i could barely go anywhere! Riht as i was pulling into the parking space the temp gauge went nuts and started climbing...i immediatly shut the car down...what is wrong?
I have a cell also...i just checked and its code 3 (map sensor)...but that is hooked up correctly...it just came on as i was pulling in
Old Aug 30, 2005 | 05:47 PM
tony n.'s Avatar
Default Re: Finished install...bogging like hell and overheating!! (TyeJ23)
did you boost any? maybe the stock map sensor is readin boost...
Old Aug 30, 2005 | 06:02 PM
TyeJ23's Avatar
Default Re: Finished install...bogging like hell and overheating!! (boosted2cam)
yes i did hit 1psi...
Old Aug 30, 2005 | 06:06 PM
EBP.EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TyeJ23 &raquo;</TD></TR><TR><TD CLASS="quote">yes i did hit 1psi...</TD></TR></TABLE>
well you just answered your own question on why you have a map sensor code. as the other problems, we prolly need more info to be able to give a reason why its happening, since its still pretty vague{sp?).
Old Aug 30, 2005 | 06:17 PM
TyeJ23's Avatar
Default Re: Finished install...bogging like hell and overheating!! (1slow4dr)
Ok heres the rundown...
We installed a thicker HG, ARP headsutds, and cam gears. We did not re-time the engine afterwards. wouldn't the lower compression throw off the timing? i also intalled an edelbrock victor X IM...
Old Aug 30, 2005 | 06:56 PM
xenocron's Avatar
If you threw a MAP Cel, chances are you threw the car into limp mode momentarily. Reset the ECU by pulling the ECU fuse or disconnecting the battery for about 5 minutes. Connect everything back up and start the car and let it idle without touching anything for a few minutes.
Dont boost until you get tuned
Old Aug 30, 2005 | 07:07 PM
TyeJ23's Avatar
Default Re: Finished install...bogging like hell and overheating!! (xenocron)
ya the map sensor prob was cuz it hit like .5 psi lol... i will take the wg spring out so i wont boost... but the overheating and bogging im still clueless really.... besides timing i dont know what else it could be.... when i would pull out no matter how much i would be on the gas it wouldnt hardly move at all, i almost didnt make it around the corner on the main road and the oil press was dropping to like 20psi
Old Aug 30, 2005 | 08:20 PM
tony n.'s Avatar
uh im not sure but i wouldnt take the wg spring out...
Old Aug 30, 2005 | 08:42 PM
TyeJ23's Avatar
jeff diff said take the spring out on the drive up to get tuned so i wouldnt be boosted at all
Old Aug 30, 2005 | 08:51 PM
RotiEatter's Avatar
Ditto
Did you bleed your coolant since you installed the new HG? New thermostat?
Old Aug 30, 2005 | 09:05 PM
TyeJ23's Avatar
Default Re: Finished install...bogging like hell and overheating!! (RotiEatter)
yes i bled the coolant, didnt install a new thermo
Old Aug 30, 2005 | 09:08 PM
RotiEatter's Avatar
Ditto
Take it out and boil it and see if it opens at the right temperature. I doubt your head gasket is already blown if you took it easy on the way home. Did you have over-heating problems before? Its probably something small and stupid like radiator cap . Good luck
Old Aug 30, 2005 | 09:16 PM
TyeJ23's Avatar
i never had OH problems before, i had the half size installed like 2 months before the turbo install and no problems.
Old Aug 31, 2005 | 11:35 AM
JDM_EH2's Avatar
ttt for more answers...when did you bleed the coolant tye? I still think theres an air bubble or two in there...
Old Aug 31, 2005 | 12:05 PM
BoOsTeD C1's Avatar
i think the bogging issue is due to running off stock ecu and injectors=not enough fuel for such big power.Stay off boost till its tuned your time to boost will soon come.
Edit:running lean also causes to overheat.
Old Sep 1, 2005 | 05:04 PM
JDM_EH2's Avatar
Default Re: (VTEC_pWrD_CiViC)
issue fixed...it was timing...thanks guys
2fastek
Oct 1, 2008 10:38 AM
5thgen
Oct 17, 2005 07:11 AM
Kidd_Stylez
Nov 2, 2004 04:14 PM
barry11j
Aug 4, 2004 09:45 AM
bubbahatch92
Nov 13, 2003 01:03 PM
