stock map thorwing code at 4 psi
Old Nov 13, 2003 | 10:35 AM
bubbahatch92's Avatar
Default stock map thorwing code at 4 psi
The wierdeist thing is happening my stock map sensor will only let me boost to 4 psi then it puts my car in limp mode. I put a one way check valve in line with the map and now i can boost. The map sensor is working though, i know this because i take it off and the car goes rick and my vaccum goes to zero. I would leave the car like this but the transition from vaccum to boost is a little choppy. I'm running a stock ecu and stock injectors with a fmu.
thanks
Old Nov 13, 2003 | 10:36 AM
Sonny's Avatar
25 Year Member
Default Re: stock map thorwing code at 4 psi (bubbahatch92)
The stock ECU cannot see boost or will throw a CEL. You need a check valve or missing link if you are not running a standalone.
Sonny
Old Nov 13, 2003 | 10:48 AM
Default Re: stock map thorwing code at 4 psi (Sonny)
but i thought the stock map sensor wasnt supose to throw a cod til 11 psi mine wont let me go pass 4
Old Nov 13, 2003 | 10:50 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubbahatch92 &raquo;</TD></TR><TR><TD CLASS="quote">but i thought the stock map sensor wasnt supose to throw a cod til 11 psi mine wont let me go pass 4</TD></TR></TABLE>
No, the stock map sensor can read up to 11 psi for a standalone. You need some type of check valve or missing link to fool it into thinking there is no boost since you have no standalone. Otherwise, you CEL will get annoying.....quick.
Old Nov 13, 2003 | 10:54 AM
Joseph Davis's Avatar
Default Re: stock map thorwing code at 4 psi (ladysman)
Stock MAP won't read to 11 psi, sorry. It's a few psi less than that, OBD specific.
Just because the stock MAP reads it doesn't mean the ECU likes what the MAP is telling it, thusly, CEL 3.
Old Nov 13, 2003 | 10:56 AM
ladysman's Avatar
Default Re: stock map thorwing code at 4 psi (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Stock MAP won't read to 11 psi, sorry. It's a few psi less than that, OBD specific.
Interesting. I always thought it had the voltage output for 11?
Old Nov 13, 2003 | 11:00 AM
Nextelbuddy's Avatar
or depending on your fuel settings using a VAFC. depending on how lean or rich you have the settings and how much boost you run will determine if u get a CEL. like right now on my current settings i can run 10 psi with no CEL.
Old Nov 13, 2003 | 11:03 AM
kpt4321's Avatar
OBDI MAP's output 2.8 volts at atmospheric. At 11 psi, that comes out to 4.9 volts, which is probably approximately the maximum operating voltage of the MAP. So, 10 or 11 psi should be the max THE MAP CAN READ.
If the ECU sees anything positive, it's going to get angry. Go with a missing link.
Old Nov 13, 2003 | 11:09 AM
Default Re: (kpt4321)
Honda MAP sensors are limited in their return voltage by physical construction; the diaphragm/wiper that travels across the potentiometer can only travel so far. You'll never get one returning 4.9 volts much less the 5.0 volt referrence.
Hint: Zdyne got it right for OBD0, Hyundaidata got it wrong for OBD1+.
Old Nov 13, 2003 | 01:03 PM
kpt4321's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Honda MAP sensors are limited in their return voltage by physical construction; the diaphragm/wiper that travels across the potentiometer can only travel so far. You'll never get one returning 4.9 volts much less the 5.0 volt referrence.
Really? That is very interesting!
How is the approximate maximum voltage it can output?
Honda4life777
Jul 6, 2009 09:00 PM
5thgen
Oct 17, 2005 07:11 AM
Raf
Feb 25, 2005 07:54 AM
mogz
Feb 10, 2004 07:49 AM
Mr. Softee
Mar 25, 2003 07:29 PM
