Finally some respectable numbers
Old May 16, 2010 | 06:26 PM
crxcel's Avatar
Default Finally some respectable numbers
Been playing with my project and finally today I got some decent dyno #
B18C1
81.5 weisco's and eagle rods
ITR camshafts
SuperTech Springs and retainers
Skunk2 manifold
Hondata IM gasket
Peakboost FTW kit, T3/T4OB 57trim .63AR
made 361hp @ 8400 @15lbs boost on 94 octane
240tq @ 7000
Old May 16, 2010 | 06:39 PM
golf-mk3's Avatar
Default Re: Finally some respectable numbers
those numbers sound kind of low for that setup
Old May 17, 2010 | 05:35 AM
dantamparacer's Avatar
it depends on how crazy the timing curve is. my car was tuned at one shop in colorado springs, and when i took it to a friend of a friends shop he said the timing was "dangerious". It made 379 on 11 psi, crazy aint it
Old May 17, 2010 | 01:35 PM
crxcel's Avatar
mine is a fairly conservative tune. Max power doesnt matter when it blows up. I am very happy with my results.
Old May 17, 2010 | 02:14 PM
092eg6's Avatar
whats the compression ratio on the motor?
Old May 17, 2010 | 02:22 PM
turbo-crx's Avatar
sounds about right for that small of a turbo.
Old May 17, 2010 | 06:50 PM
Hawjap1gsr's Avatar
looks good.
Old May 18, 2010 | 05:53 PM
crxcel's Avatar
8.9:1
Old May 18, 2010 | 06:49 PM
092eg6's Avatar
Originally Posted by crxcel
8.9:1
IMO that compression ratio is kinda low, i would stick with the 10:1cr ratio, i think it would of made more power with the stock GSR compression ratio..
Old May 18, 2010 | 06:58 PM
solo227's Avatar
+1
With that compression... Those numbers look good...
Up the boost and enjoy the car...
Old May 19, 2010 | 07:00 AM
DA TeG 90's Avatar
For the street, those are great numbers!
Old May 19, 2010 | 09:52 AM
96 GSR-T's Avatar
FYI 9:1 is the norm when building a boosted honda motor that is going to run on pump gas....
That 1 point in compression is worth 10-20whp and thats it.
Old May 19, 2010 | 06:21 PM
blackeg's Avatar
the turbo isnt that small, i made 300whp on 8 psi with the same turbo/peakboost version1 kit and only 21* total timing with a friends gsr.
that setup could make 400 no doubt the way it sits, if that was your goal.
crxcel, you are 100% right that max power dont matter when it blows up. 361 is perfect for the street and the motor will go a very long time on it. now all you have to do is stay up on oil changes and take the car wherever you want to go.
Old May 19, 2010 | 07:34 PM
crxcel's Avatar
as a baseline of last year, total stock GSR with smae kit and 750 injectors and it made 240hp @8lbs. just changing camshafts, intake and pistons, it made 290hp @ 8lbs this year, so I dont think that the compression hurt me. And you guys are right perfect street motor, thats where it spends 90%of its time.
the_yblegal
Engine Management and Tuning
Jun 2, 2014 04:50 PM
HarfordCTR
Dec 21, 2007 07:06 PM
jarvis199
Nov 1, 2006 11:02 AM
b18junkie
15
Aug 21, 2003 05:07 AM
ILOVEGIRLS
Jul 10, 2001 10:34 PM
