Finally!!!!
Old Nov 12, 2003 | 03:39 AM
GDM Z28's Avatar
Default Finally!!!!
i finally crossed over to the dark side! i am now a proud owner of a boosted b18b in a EG hatch! i will take pics today after the downpipe is made. but i was wondering if someone could give me safc settings.... im not sure what to set it at. im gonna run 7-9 psi on a b18b with a t3 turbo, 450 cc dsm injectors and a tial 38mm wastegate. the system is intercooled. if you have any sudgestions for afc settings please post them. thanx man.
Old Nov 12, 2003 | 03:51 AM
EFb18b's Avatar
Default Re: Finally!!!! (civicflnum1)
Congradulations! welcome to the dark side and have fun with your new toy! As for afc settings, I can't help you there but I'm sure somebody can or maybe something will pop up during a search.
Old Nov 12, 2003 | 06:49 AM
baddassduramax's Avatar
Default Re: Finally!!!! (Redlineracer)
set all of ur afc settings at about -38% to start out, except your 1000 rpm setting, around -28% so it will idle. that should give you some leeway to play around as all motors will be different, thats what i started out with!
hope that helps
Old Nov 12, 2003 | 06:50 AM
OnePointFive's Avatar
overrated.
Default Re: Finally!!!! (civicb18)
congratulations, i hope to be a LS-Turbo owner myself within the next few months.
Old Nov 12, 2003 | 07:10 AM
Johnyquest's Avatar
Default Re: Finally!!!! (OnePointFive)
To start off, do it like this:
Hi/lo crossover @ 70/71%
then, 1000 rpms on lo to -34
rest of low through 8k rpms to -36
all of high throttle 1-8k @ -37 to start. it should run good like this.. Also, I reccomend dropping the timing with you distributor about 3-4 degrees, for safetys sake.
Old Nov 12, 2003 | 07:13 AM
VTC_CiViC's Avatar
Default Re: Finally!!!! (Johnyquest)
I'd start the idle leaner, closer to -40% and run the rest of the map as rich as possible before the car throws a CEL. This will have you running really rich, but will also keep you on the safer side till you can throw it on a dyno and pick up some A/F numbers.
Don't forget to back the timing 2-3 degrees!
Oh yea, welcome Trent
Old Nov 12, 2003 | 07:47 AM
M.A.R.C.'s Avatar
Default Re: Finally!!!! (VTC_CiViC)
hehehe good stuff trent. the darkside ownz joo
Old Nov 12, 2003 | 09:03 AM
CLUNKER's Avatar
Default Re: Finally!!!! (CivicRyda2k)
bah.. trents car owns me... i spent 2 days almost non stop working on that ****.. lol. youd better let me drive it fool.
Old Nov 12, 2003 | 09:53 AM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">I'd start the idle leaner, closer to -40% and run the rest of the map as rich as possible before the car throws a CEL. This will have you running really rich, but will also keep you on the safer side till you can throw it on a dyno and pick up some A/F numbers.
Oh yea, welcome Trent </TD></TR></TABLE>
yes thank you so much!!! if it wasnt for you id have to wait 2 weeks to get a downpipe flange from SFP...grrr those guys pissed me off...but thanx man! and yes thank you eric for all your help on the install. i owe you guys big time!! BTW when i started the car the first time it was smoking alittle...i couldnt tell what color it was cause it was dark but could it be from no down pipe and have the 450's running really really rich? it smelt like exhaust and fuel...im praying the turbo is good. it should be though.
Old Nov 12, 2003 | 10:29 AM
VTC_CiViC's Avatar
The turbo is fine, get an exahust on there and drive her a bit. There's alot of grease, oil burning off the manifold and other hot parts.. should clean off withing an hour or so of driving.
Old Nov 12, 2003 | 04:44 PM
HaTcH_BmX's Avatar
congrats trent... hope you give me a ride like you promised me.. !! your car is really nice.. it really is !! congratulations
Damian
Old Nov 12, 2003 | 05:24 PM
NuclearB18B's Avatar
Default Re: Finally!!!! (HaTcH_BmX_Ep3 kid)
nice
spike
Feb 28, 2008 12:23 PM
boostdc
Jun 21, 2004 06:36 PM
brandond
Apr 27, 2004 02:27 PM
94B18B1Teg
Apr 26, 2004 07:25 PM
civichbb18
Apr 21, 2004 11:18 AM
