a final answer on how to hook greddy catch can on b18c1 please help
ive searched through all 1,000,000 posts on catch cans and cant seem to find a simple answer on how to install it. I want to install it so i dont have a pcv system anymore i dont care about emmisions, is this the correct way to do it??. how do i do it thanks.....
one inlet to the top pf the valve cover on your breather, the other outlet goes to your intake piping before turbo
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">one inlet to the top pf the valve cover on your breather, the other outlet goes to your intake piping before turbo
stan
With this setup, do you just leave the PCV valve in place anyway and not worry about it? I'm having issues figuring out the best way to install my catch can as well.
Thanks a lot for any additional information.
Mark
stan
Mark
this is going to sound completely retarded but where is the pcv valve on my b18c1 motor??? there is only one outlet on the valve cover and i cant see it anywhere on my intake mani??? i feel like such a moron asking this....and also how will the catch can catch anything the way you said to do it???? i have a breather on there now what is the difference??? im not being a wise *** i really don know..thanks
if you look under the intake manifold, you'll see a black box with red plastic fitting on top of it, then a black hose, the red thing is the PCV valve.
stan
stan
so should i hook it up in between the intake mani and the pcv valve or from the calve cover to intake pipe before turbo???
this will help you...http://www.c-speedracing.com/howto/c...n/catchcan.php
