Catch can questions
Old Oct 18, 2007 | 10:25 AM
totsie7944's Avatar
Default Catch can questions
Ok so I've read up and understand perfectly how to install the catch can...
my thing is that Endyn apparently hasn't gotten the greatest review, but they are the only BAFFLED catch can WITH a breather I can find.
I would rather not tap into the valve cover to breath the crank case so are there any other options? Maybe just use the Moroso tank? Tap into a greddy catch can and weld a nipple with filter on end?
Old Oct 18, 2007 | 11:41 AM
SOHC_MShue's Avatar
Default Re: Catch can questions (totsie7944)
I would tap the valve cover. Its gonna give the best breathing.
Old Oct 18, 2007 | 11:45 AM
totsie7944's Avatar
Default Re: Catch can questions (SOHC_MShue)
yea but if I do this dont I need lilke two catch cans then?? One for the back of the block to eliminate the PCV valve and box, and then one up front for the lines tapped into the valve cover?
Doing both would give the best ventilation no?
Old Oct 18, 2007 | 12:09 PM
BoostedJeff's Avatar
http://www.t1raceparts.com/pro...n.htm
Do it once, Do it right.
Old Oct 18, 2007 | 12:15 PM
totsie7944's Avatar
Default Re: Catch can questions (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">
Do it once, Do it right.</TD></TR></TABLE>
where would you wanna mount that thing in your engine bay....haha. I was looking into these as well. Does it come with all the parts, fittings needed?
boostedcivicsir's Avatar
Mr. Badwrench
endyn cans work great with mild hp. mine worked well last year, at 25 psi and 500hp +- now, with 34 psi and more power, i have a 1 1.3qt can and it isnt enough.
in this day and age, i think jeff is right do it once, with the t1 can, i am taking bids on my spare kidney to get mine he hee.
mounts where the batt is.
Old Oct 18, 2007 | 12:21 PM
totsie7944's Avatar
Default Re: Catch can questions (boostedcivicsir)
yea but I have my battery where the battery is supposed to go lol....what then? Keep in mind, my R will be making 500 pump -600+ on C16, full interior, AC and PS...I dont' wanna start putting batteries in the back of the car to be honest.
This thing is really bulky, and two endyn cans could fit easiliy in the front and back is my only thinking.
besides this can drains back into the pan, which isn't always oil, its also unburned gas and oily residue....hense why I'd rather have it draining into a plastic bottle or something, or just drain it once a week....
thoughts?
Old Oct 18, 2007 | 12:33 PM
My thoughts are that there are enough people on here that have already DEALT with the problems from using those style cans. Just move your battery, its not really that big of a deal, you don't have to move it to the back, just get creative.
I would rather spend the 250 for the T1 junx, then have to worry about oiling down the track, or it spewing out, getting on your tires and you hit the wall at 120+ going down the track. Trust me, I've watched this happen more than once. Think about the big picture instead of not wanting to move your battery, sometimes you have to make sacrifices in order for things to be correct.
Old Oct 18, 2007 | 12:39 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">My thoughts are that there are enough people on here that have already DEALT with the problems from using those style cans. Just move your battery, its not really that big of a deal, you don't have to move it to the back, just get creative.
you make a valid point sir, and have convinced me lol...plus it looks killer sexy in the engine bay. Question is where to relocated the battery. Never done it before. I'm doing all my own work, but I guess I might be paying you to tap my valve cover and move the battery to the trunk for me....could you give me an estimate on tapping valve cover and battery move? lol
Old Oct 18, 2007 | 12:44 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">Question is where to relocated the battery. Never done it before. </TD></TR></TABLE>
In front of the front tire on either side seems to be the popular opinion.
Old Oct 18, 2007 | 12:53 PM
Here are a couple different options when it comes to relocating your battery
courtesy of mikey (boostedcivicsir)
Old Oct 18, 2007 | 01:02 PM
daddy's Avatar
check out this link for more battery relocation ideas:
https://honda-tech.com/zerothread?id=2105963
Old Oct 18, 2007 | 01:34 PM
totsie7944's Avatar
Default Re: Catch can questions (daddy2be)
sweet thanks guys....looks like I'm going to need a smaller battery unless I put it in the back haha
Old Oct 18, 2007 | 02:23 PM
B R Fittings's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">sweet thanks guys....looks like I'm going to need a smaller battery unless I put it in the back haha</TD></TR></TABLE>
If you need any help let me know. We have a setup that would be perfect. Good luck.
yyyktk1
Aug 10, 2014 04:08 PM
Destructive-
Jun 21, 2011 04:42 PM
Droolin
Nov 17, 2010 12:30 PM
potatobiker8
Mar 13, 2007 12:10 PM
ATS*Mark
Apr 25, 2004 08:57 AM
