A few greddy turbo questions...
Since i have the greddy turbo kit that already has a charge pipe,etc. can i use that greddy ones to make the piping needed to connect to the intercooler???(i can weld a flange to it for the BOV right???(any recommendations on which greddy BOV to get???)also can i get the necessary silicon coupling and the clamps at a local harware store for the intercooler piping???thanks
also can the 19t turbos boost be turned up even though it is internally wastegated???
Re: A few greddy turbo questions... (joshcivic00)
1. that charge piping included in the kit is for the non-intercooler set-up. only the upper charge pipe can be used.
2. a flange can be welded to the intercooler
3. type S or type R if over 12psi, or the new RS
4. hardware stores sell plumbing couplers which over time will swell and blow
5. just because a turbo is internally gated doesnt mean that you cant turn up the boost. manual boost controllers work great on internal wastegated turbos but just watch for boost spike. i would worry more about your fuel management set-up before turning up the boost expecially if you are running the blue box.
S2Kricer
06-06-2006 10:51 AM
B00ST2nR
10-28-2004 11:32 PM
Black R
04-08-2004 09:40 PM
