Feed Lines
Old Mar 11, 2003 | 08:43 AM
5thgencivic's Avatar
Default Feed Lines
I read the topic here about Greddy Feed Lines https://honda-tech.com/zerothread?id=319213 This is everything needed to bolt right up right? Anybody have a part number for the copper washers?
1. FCM2000 -- -3AN x 1/8 fitting adapter
2. FCM1100 -- -3AN Straight Hose End
3. FBC0300 -- -3AN Telfon Racing SS Braided Line (atleast 4 ft)
4. FCM1100 -- -3AN Straight Hose End (Same as #2)
5. FCM2947 -- -3AN x 10mm Banjo
6. FCM2923 -- 10mm x 1.25 Banjo Bolt
How are those hose ends put on the braided hose? Is it something I can do myself? nobody on island has the fittings or tool to put the fittings on... And my car is down because of a hole in the line. Hopefully I can order from summit today and have the parts by this weekend. Thanks for any help you can give as it is highly appreciated.
Nate
Old Mar 11, 2003 | 10:07 AM
Flamenco-T's Avatar
Default Re: Feed Lines (5thgencivic)
you need a special flaring tool to assemble the hose ends on a -3An lines, they're teflon coated and also almost impossible to do it by hand...
IM me, I sell oil feed line kit...
stan
Old Mar 11, 2003 | 10:14 AM
DeepSi's Avatar
Default Re: Feed Lines (Flamenco-T)
it was somewhat difficult to put on by hand but i was able to do it. They are all the parts necessary for the TDO5 turbos. I am not sure the ones that Stan sells are for the greddy turbos, but for other turbos if i am not mistaken.
Old Mar 11, 2003 | 11:00 AM
I sent you an IM.
Thanks guys.
Old Mar 11, 2003 | 11:29 AM
Flamenco-T's Avatar
Default Re: Feed Lines (DeepSi)
yeah, I have all kit for all turbo, 4 bolts, 5 bolts, T25, T28, 16G, 18G, T04 anything you can think of...
Old Mar 11, 2003 | 11:33 AM
DeepSi's Avatar
cool
Old Mar 11, 2003 | 11:49 AM
Perfect I'll actually be able to run my boosted car for the first time... As long as nothing else goes wrong
Nate
Mr_ET
May 15, 2007 02:23 PM
Dunc
Jun 18, 2006 09:30 PM
ntegls
May 1, 2003 06:31 PM
jthelman
Sep 11, 2002 01:49 AM
Xerxes
Jan 27, 2002 10:48 PM
