F-max kit?
Old Jan 28, 2002 | 07:38 AM
sivik2nr's Avatar
Default F-max kit?
I'm wanting to install that F-max turbo kit by springtime, and I'm kinda wondering, does anyone think that it WON'T work well with my D16Y7?? I'm having trouble with the whole thing about the 2 (only two??) fuel injectors they supply. I wanted to run it at 7 or 8 psi max, with a stock block. That should be pretty safe, right? If I get a new fuel pump ,rail , injectors, and an A/F ratio meter to closely monitor it, that should fix any fuel prob's , right? That should make my little hatch move quite a bit i'm thinkin.. ahah Anyone had problems with this kit?
thanks
Old Jan 28, 2002 | 09:48 AM
JM Performance's Avatar
Default Re: F-max kit? (c_spec)
Search....if you have specific questions, I can help you, but there has already been A LOT of debate on the MF2. Use the search function......you'll find it.
Personally I like the MF2 over fmu....but it still has nothing on standalone.
mooseknuckle
Mar 1, 2004 04:15 PM
Jkan2001
Aug 12, 2002 12:48 AM
Sohc Driver
Feb 27, 2002 09:14 AM
crxnug
Jan 30, 2002 05:46 PM
MisterB
Jan 13, 2002 06:41 AM
