experienced ppl...new headgasket or head bolts? overheating in boost
My engine is overheating when i go into boost. The engine is newly rebuilt. I retorqued the head bolts which were about 15ft-lb off spec and the car ran fine while i was driving it hard (boost). I didn't see any overheating for two days. The car is starting to overheat again. I need some opinon on whether i need new head bolts (have mine been stretched past yeild strength?) or if its the head gasket. Thanks guys, i'm stumped
Re: experienced ppl...new headgasket or head bolts? overheating in boost (VTgringo)
Did you reuse your old head bolts? If you did, they might have streched. I recommend running a nice set of ARP's if you need new ones.
Whenever you overheat when going into boost there is a sealant problem with the headgasket. I would say get new headbolts, a new OEM headgasket, and also check the deck of the head and block.
Re: experienced ppl...new headgasket or head bolts? overheating in boost (GudeH23a)
Thanks for the reply. I'm really hoping that i won't have to replace the head gasket in this weather (no garage). I don't even want to think about the idea of the head or block being warped...ugh. I love this car but its taken up too much of my time and money.
well i just started it up and took the rad cap off. I saw those infamous black oil droplets......i guess that solves that one. I'm going to get a new head gasket and arp head stud set.
VTgringo
12-20-2003 01:11 PM
Ri5e
09-09-2002 01:13 PM
