evolution 8 turbocharger
Old Dec 24, 2007 | 03:19 PM
integraRS-T's Avatar
Default evolution 8 turbocharger
i just wannt to find some things out bout this turbo,is it a 16g or 18g i know its good for bout 380hp but at how many psi? what are the ar.s on it and how many horses can i get per psi any info i greatly appreciated thanks
Old Dec 24, 2007 | 03:39 PM
Garage 808 Hatch's Avatar
Default Re: evolution 8 turbocharger (integraRS-T)
it all depends on the setup, the tuning etc. we have made 312 on an evo 8 turbo, on a straight LS setup all stock with ARP rod bolts, 17-18lbs. and 285 on 14lbs on another LS forged internals (customer ran out of injector). we have yet to use one on a Vtec setup, or go over 18lbs YET.
Old Dec 24, 2007 | 03:40 PM
ChampWhiteTegra's Avatar
they say its an 18g but realy its closer to a 20g. they run 20psi stock on a 2.0l . on a honda u should seefast spool and nice power band
Old Dec 24, 2007 | 03:47 PM
how many psi are they good for and what is the inducer and hot side ar's
Old Dec 24, 2007 | 06:23 PM
TheShodan's Avatar
Moderator
Default Re: (integraRS-T)
The Evo 8 turbocharger is closer to an 18G. It is a larger twin scroll 16g good to about 350whp, but that is pushed on evolutions over 22psi. it is a 650cfm turbocharger. A/R sizes are a bit different than what they are used to in terms of square cm, and not the standard ratios you're used to associating with.
Marc_Smith
Jan 29, 2010 02:49 PM
SILENTJ95835
Apr 12, 2006 03:38 PM
123Four
Jun 8, 2005 10:41 AM
sleepin91teg
Nov 9, 2004 04:25 PM
SimonsTeg
Aug 13, 2002 09:15 PM
