Is it possible to swap...
Old Dec 23, 2007 | 09:50 AM
EX-T's Avatar
Default Is it possible to swap...
....the shafts of a Turbonetics and Garrett turbo? I have a .63 a/r turbine housing on both but the wheels are different and I need the turbine housing from the Turbonetics with the center section and compressor housing of the Garrett b/c the turbine housing on the Turbonetics is a 5 bolt and the turbine housing on the Garrett is a 4 bolt and I already have a 5 bolt downpipe and really don't want to buy a new DP and the Turbonetics turbo needs a new compressor wheel and center section.
Old Dec 23, 2007 | 12:13 PM
DA_HONDA_BOY's Avatar
Default Re: Is it possible to swap... (EX-T)
buy a new flang for your turbo
Old Dec 23, 2007 | 01:36 PM
HiProfile's Avatar
There are a shitload of 'garrett' turbos that will not, and a few that will. Chances are you have a stg3 turbonetics turbine, and a stg1 turbine on the garrett.
Would you really want to kill your power by 10-20% by going with the smaller Garrett turbine? Otherwise you'll ahve to disassemble both turbos, try it out, then have it rebalanced. Trust me when I say its easier & cheapter to cut & weld for the 4-bolt. You may find someone with the 5-bolt housing, but typically thats a $50-100 upgrade for the off-the-shelf turbos.
Old Dec 24, 2007 | 06:36 PM
EX-T's Avatar
Default Re: Is it possible to swap... (HiProfile)
The Garrett Turbine wheels is bulkier than the Turbonetics piece. I got my new center section for my Turbonetics today. All I need now is a compressor wheel, I don't have a clue where to get one for cheap and a rebuild kit.
Old Dec 24, 2007 | 06:44 PM
turbodano's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">The Garrett Turbine wheels is bulkier than the Turbonetics piece. I got my new center section for my Turbonetics today. All I need now is a compressor wheel, I don't have a clue where to get one for cheap and a rebuild kit.</TD></TR></TABLE>
We have all the turbo rebuild parts you could ever want.
alexsracing
May 3, 2009 01:11 PM
blueturbo4door
May 3, 2005 08:00 PM
