engine not getting vaccum?
Old May 22, 2015 | 03:13 PM
93ls10.0's Avatar
Default engine not getting vaccum?
Setup:
B18b
wisecracking
Eagle
p&p P75 head
ferret valves +1mm intake
ge manifold
76mm Blox tb
Web dual springs
delta cams
Swap has been sitting about a year was running in my da. I thow it in my ek and can't get it to idle at all. Gauge is showing 1lb vac at 1k rpm. Spits stumbles rev to 2k-2500 reads 12 vac I don't understand what the problem could be. Checked timing multiple times set valve lash multiple times. What else would be the cause for having no vac at lower rpm?
Old May 22, 2015 | 04:24 PM
KevinEF7's Avatar
Default Re: engine not getting vaccum?
a vacuum.......... leak
Old May 22, 2015 | 05:34 PM
civic-steve-94's Avatar
Check basics first is my advise.
Compression test and depending on results leak down
Old May 22, 2015 | 08:24 PM
93ls10.0's Avatar
Did comp 120psi across the board it is a 8.1 motor
Old May 23, 2015 | 06:32 AM
Do a leak down and see where your compression is going.
Old May 23, 2015 | 04:14 PM
viper_boy403's Avatar
incorrect spark timing... plug wires on wrong. Given that timing and compression are good, and it remains the same mechanically from when it last ran, that's really all you've got left
Old May 24, 2015 | 06:26 PM
93ls10.0's Avatar
Firing order is correct that's the first thing checked before I dug deeper
getnasty
Mar 24, 2010 10:47 AM
turbo-crx
Jun 10, 2009 11:18 AM
memorybox
May 13, 2009 01:01 PM
LostCRX
Apr 26, 2004 06:16 AM
Cone
Jun 23, 2003 02:51 PM
