Engine Managment
Old Feb 6, 2005 | 07:01 AM
  #26
Kowalski's Avatar
Default Re: (drvfast)
Uberdata 1.7
Old Feb 6, 2005 | 08:08 AM
  #27
Jefnes's Avatar
Default Re: Engine Managment (lugnuts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lugnuts &raquo;</TD></TR><TR><TD CLASS="quote"> I just cannot understand why so many people have such a high a tolerance for **** that doesnt work until the 19th revision,if at all. Can someone please explain it to me?</TD></TR></TABLE>
It is the Microsoft mentality....
We have been brainwashed into thinking that bugs are 'ok'.
Jeffrey Atwood
Old Feb 6, 2005 | 02:06 PM
  #28
Lmgrcivic's Avatar
where do you buy uberdata from where can I find a dealer
Old Feb 6, 2005 | 02:12 PM
  #29
BlueShadow's Avatar
Default Re: (Lmgrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic &raquo;</TD></TR><TR><TD CLASS="quote">where do you buy uberdata from where can I find a dealer </TD></TR></TABLE>
Uberdata is free, you only have to pay for the equipment needed to run it, laptop, WBO2 setup (optional), ECU chipping supplies. Check out the Keebler link and the Uberdata forums link in my sig.
Old Feb 6, 2005 | 04:11 PM
  #30
st00pid's Avatar
Default Re: (BlueShadow)
Houston Neptune dealer here.. Awesome system very versatile, so many options you get carried away playing with them all!! Less expensive than Hondata with more options and adjustability.
Old Feb 6, 2005 | 06:54 PM
  #31
fperra's Avatar
So Uberdata only works with OBDI? Out of luck with OBDII?
Old Feb 7, 2005 | 03:21 PM
  #32
BlueShadow's Avatar
Default Re: (fperra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fperra &raquo;</TD></TR><TR><TD CLASS="quote">So Uberdata only works with OBDI? Out of luck with OBDII?</TD></TR></TABLE>
Do an OBD 2 to OBD 1 swap...all you gotta change out is your ECU and get an OBD 2 to OBD 1 conversion harness. You can get a stock obd 1 manual P28 for less then $150 and a conversion harness should be $90-$120.
check out this thread for reference:
https://honda-tech.com/zerothread?id=1015108
Old Feb 7, 2005 | 03:29 PM
  #33
beerbongskickass's Avatar
Been running Uberdata for a year without any problems...
brkdwn5
Sep 18, 2005 05:00 PM
88crxhfb16
Jul 16, 2005 08:46 PM
CrazyHB
Aug 13, 2004 06:17 PM
Boosted GSR
May 2, 2003 11:52 AM
symba
Dec 10, 2002 10:01 AM
