engine management?
Old Jul 10, 2007 | 10:41 AM
00garrettsi's Avatar
Default engine management?
i have been lookind at engine managements for my setup and im stumped on wheather to get hondata s200 with boost option or s300 please help thnaks.
2000 si
garratt gt28rs turbo
Old Jul 10, 2007 | 11:01 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: engine management? (00garrettsi)
either way you need to convert to obd1, i think the cost in the long run the s300 is cheaper. plus from what i have heard tony1 says the boost control is the cats ***. i cant wait to try it.
Old Jul 10, 2007 | 11:09 AM
mtber's Avatar
hondata.com will describe all of the differences between the systems.
If your looking at buying s200, I would recommend you simply go with the s300 system.
Old Jul 10, 2007 | 11:13 AM
PrecisionH23a's Avatar
S300 all the way with the boost control. The GM solenoid is $60, the install hardware is $15, and the installation into the ecu is $50. I also think the s300 boost control is the best option available for the amount of money it costs.
You have 2 different ways to manage boost... a fixed duty cycle or a gear based duty cycle which allows you to have a low and high setting.
Old Jul 10, 2007 | 01:57 PM
Default Re: engine management? (PrecisionH23a)
i didnt know the s300 had boost control
sikasscivic
May 18, 2011 04:18 PM
imationdawg
Jul 22, 2009 05:24 PM
ONE*SICK*FERIO
Jun 26, 2008 01:46 PM
TehGhett0P1mp
May 23, 2008 09:20 PM
'Lude01
Jul 10, 2007 06:15 AM
