Engine Management @ 6 psi
Old Aug 26, 2003 | 08:18 AM
White Lightnin's Avatar
Default Engine Management @ 6 psi
A local guy is selling his JRSC for 1250. Im thinking of getting it, but I need to know what engine management I should run for reliability and afordability.
I did a search and only found options for higer boost.
TIA
Old Aug 26, 2003 | 08:23 AM
drvfast's Avatar
Default Re: Engine Management @ 6 psi (White Lightnin)
hondata
EpDarks's Avatar
IMO, it's not worth spending the money for a Hondata or another stand-alone type of management.
I'd get an Apexi-VAFC, get a few hours on the dyno, and be done.
Old Aug 26, 2003 | 08:26 AM
Default Re: Engine Management @ 6 psi (EpDarks)
What would be needed w/ the VAFC? Any other mods. If I buy the thing I plan on leaving it at stock boost for quite a long time.
Old Aug 26, 2003 | 08:28 AM
metal-x's Avatar
if you just plan on running 6psi a FMU, bigger fuel pump,colder plugs would do ok
but yeah if wanna be on the safe side hondata for sure
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Engine Management @ 6 psi (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">hondata </TD></TR></TABLE>
I second that. I thin theres no other way.
Old Aug 26, 2003 | 08:31 AM
Default Re: Engine Management @ 6 psi (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">
I second that. I thin theres no other way.</TD></TR></TABLE>
Yeah, I don't want to go cheap. Need to do more research and look at my budget. Thanks guys.
Old Aug 26, 2003 | 08:36 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I think if you half step, it will catch you in the long run.
Old Aug 26, 2003 | 08:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">I think if you half step, it will catch you in the long run.</TD></TR></TABLE>
Yeah, I've already learned this many times buying cheap used parts. Thanks for the input guys.
BTW How much does the base stage Hondata with boost run?
Old Aug 26, 2003 | 08:41 AM
Nextelbuddy's Avatar
hey white lighting im in atl too. u must be talkin about jeremys charger for sale. he has the hondata for sale from hsi charger that is tuned for it for like 375 i would get it if possible. but if not then get the vafc. i am running the VAFC hack on my b18c1 in my 95 hatch with t3/t4 E setup at 4-5 psi and it works great. no problem no hesitation and no leaning out. pulls nice all the way to 8000 rpms. but if u can fork out the extra cahs get his hondata i was going to but i got a vafc for 150 bux thats why i didnt.
Old Aug 26, 2003 | 08:50 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Lightnin &raquo;</TD></TR><TR><TD CLASS="quote">
BTW How much does the base stage Hondata with boost run?</TD></TR></TABLE>
Depends on where you get it from. I can get you one IM me.
Default Re: Engine Management @ 6 psi (nextelbuddy)
It all comes down to a money issue. Im in school and on a budget.
Time for some creative accounting to fool the parents and girlfriend.
You guys think I could get out of the deal w/ tuning and hondata, fuel pump etc for less than 2000?
Old Aug 26, 2003 | 08:53 AM
well balanced performance is having a special right now 900 bux for hondata s200 with boost option and tuning. not a bad deal. but along with the charger for 1250 then thats a little over 2000. i say get the hondata from the saem guy whos selling you the charger he has it for like 375 already tuned for the charger on a b18c1
Old Aug 26, 2003 | 08:54 AM
vtec.dc2's Avatar
i'd say hondata, you car is already obd1, so you can re-chip ecu for $50.. buy used hondata, i'd recommend the new s200.. but older stages will do if you want to save money. then high pressure intank fuel pump and larger injectors, and f.p.r. wouldn't hurt. half the price of what your fi parts, but a good investement.
Old Aug 26, 2003 | 09:09 AM
gitwidit's Avatar
Default Re: Engine Management @ 6 psi (vtec.dc2)
go hondata, when you get used to the jrsc@6psi then you can use the hondata nitrous controls to give you that "new car feeling" again
Old Aug 26, 2003 | 09:24 AM
ArtOwnzMe's Avatar
Yeah, I don't want to go cheap. Need to do more research and look at my budget. Thanks guys.</TD></TR></TABLE>
sure you can go cheap
https://honda-tech.com/zerothread?id=572526 PRetty much no differnece between that on hahnduhta.
Old Aug 26, 2003 | 10:50 AM
FuzzyGreen's Avatar
Default Re: Engine Management @ 6 psi (ArtOwnzMe)
Does this boost editor really work? Does it perform like a stock production boosted car? Usually when things are too good to be true they usually aren't.
Old Aug 26, 2003 | 10:57 AM
ArtOwnzMe's Avatar
Default Re: Engine Management @ 6 psi (FuzzyGreenCarpets)
i run it in my car, as do many oithers
Old Aug 27, 2003 | 07:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArtOwnzMe &raquo;</TD></TR><TR><TD CLASS="quote">i run it in my car, as do many oithers </TD></TR></TABLE>
I've got the basics of how this work, but is there a place I can get hard info? An FAQ perhaps?
love2xlr8integra
Apr 5, 2004 04:29 PM
int3gra
Apr 2, 2004 07:22 AM
int3gra
Mar 22, 2004 12:53 PM
durden
Jan 3, 2004 03:10 PM
NeXtLeVeL_TyPe_R
Apr 17, 2002 10:37 PM
