engine falls on its face at 1/4 throttle on boost!
Old Apr 10, 2005 | 01:44 PM
AutoTrenz702's Avatar
Default engine falls on its face at 1/4 throttle on boost!
whenever i give the car more than 1/4 throttle on boost it boggles and pops until i ease off the throttle a tad ! any advice on this ? ive tried 3 different map sensors and 2 different missing links! the motor is a stock gsr on 7lbs of boost!
Old Apr 10, 2005 | 01:52 PM
nonvtecD's Avatar
Missing link eh? You're using an FMU then? is it throwing a code. I'm tempted to tell you to get some real EMS but i'll refrain for now.
Old Apr 10, 2005 | 02:10 PM
SOHCmaster's Avatar
does it sound like popcorn through the exhaust, when mine starts poppin I know my plug gap is no good and I change plugs w/new gap
Old Apr 10, 2005 | 03:54 PM
It does make a popcorn sound at anything more than 1/4 throttle ! and yes ! i do have the fmu 12:1 and stock gsr ecu, walbro fuel pump and stock injectors and the wastegate is set @ 7.lbs.
Old Apr 10, 2005 | 04:58 PM
SOHCmaster's Avatar
All I can suggest is change plugs and gap em at 28-34. I do mine at 32
Old Apr 10, 2005 | 09:43 PM
PrettyLude's Avatar
you are probably run dead lean, you need to hook up an inline fuel pump if you are using a fmu, and make sure the missing link is installed the correct way, its only supposed to go on only one way
Old Apr 11, 2005 | 01:48 AM
Im going to replace my fuel pump within the next day or two ! and new injectors
Old Apr 11, 2005 | 02:43 AM
Zakar's Avatar
you could burn down that expensive engine easily... injectors need to go on with the rest of the setup..
b18bteg14
Dec 10, 2006 02:46 PM
Integra_RS
Aug 4, 2005 07:28 PM
droc327
Jun 21, 2005 10:40 PM
kholmes
May 10, 2004 07:08 PM
DDD
Mar 25, 2003 03:31 PM
