Engine build up
Old Jun 10, 2004 | 04:42 PM
95GSRTT
Guest
Posts: n/a
Default Engine build up
Well I have decided to finally build up my bottom end. I was gonna just do GE sleeves with CP pistons and eagle rods.
My tuner says I should go with RS sleeves and honing. Which I hear is also good and he can get that done with hone for 800 bucks.
My main question is, he wants me to allow him to install my pistons and rods. He said it will be about 500 bucks for him to install them. B/c he is going to blueprint and everything. Is blueprinting really worth $500? I will have the crank polished and the pistons/rods/crank balanced.
Old Jun 10, 2004 | 05:43 PM
95GSRTT
Guest
Posts: n/a
Default Re: Engine build up (95GSRTT)
someon has got to know whether blueprinting is really that beneficial.
Old Jun 11, 2004 | 08:24 AM
95GSRTT
Guest
Posts: n/a
So does no one do blueprinting?
Old Jun 11, 2004 | 02:02 PM
System-7's Avatar
yes it is. have him do it. i dropped 650 to get all my bottom end installed, measured etc.
Old Jun 11, 2004 | 03:13 PM
drvfast's Avatar
sounds like a fair price
Old Jun 12, 2004 | 09:49 AM
95GSRTT
Guest
Posts: n/a
Default Re: Engine build up (drvfast)
what exactly does blueprinting do for you?
Old Jun 12, 2004 | 09:59 AM
EG-6Ghost's Avatar
blue printing makes sure that all parts are at the right specs....If your eninge parts are way out of wack you engine will not last as long under hard abuse...
Old Jun 12, 2004 | 01:35 PM
Sunrise City Rider's Avatar
Default Re: Engine build up (EG-6Ghost)
Blueprinting is the process of measuring every clearance and weighing the complete rotating assembly to eliminate unwanted vibrations, weight, and clearances...This allows your engine to "sing" like Jessica Simpson and not like William Hung...
This takes time and patience and the person blueprinting the engine should have all the specs documented and make adjustments to perfect the balance of the parts...
You need to make sure that the engine builder will take the time to balance the engine as well as blueprint it...Ask for them to record the specs for you to view...This will make sure that you have not wasted your money on some salesman instead of a engineer...
Old Jun 12, 2004 | 01:56 PM
95GSRTT
Guest
Posts: n/a
Default Re: Engine build up (Sunrise City Rider)
ya he said he would blue print and document and give it to me. for 500 bucks that aint too bad i hear.
Old Sep 1, 2005 | 11:41 PM
White_EK49's Avatar
that's is fucked up!
Old Sep 2, 2005 | 06:49 AM
turbosi03's Avatar
Default Re: Engine build up (slow29)
you definately want to know if your motor is in spec before you put it together
the only thing is you have to trust the person doing the blueprinting... all he's doing is double checking the machinists work (in your case GE)
turbotime
Jan 8, 2006 04:22 PM
p1ccoloz
Feb 7, 2004 08:46 PM
Cyber ITR
Jan 19, 2004 03:14 PM
BlueSi2k
Jul 31, 2002 09:14 PM
Trajic
Sep 5, 2001 08:28 AM
