Endyn catch can removal, how to take of aluminum plug???
Well I am having trouble taking my endyn breather off, there is a stamped aluminum plug to fill the stock breather hole that you have to tap in, I cant get it out. I tried punching a hole in it, beng it, grabbing the edge with pliers, nothing. this sucks, anyone have experience with this?
Re: Endyn catch can removal, how to take of aluminum plug??? (ProjectDarkBlack)
if its a freeze plug, you have to knock it sideways with a punch or something, then pull it out with vicegrips
Re: Endyn catch can removal, how to take of aluminum plug??? (dturbocivic)
sounds like an idea. I biting in to the hole with a screw, the yanking on the screw. Not a
good idea, the tip broke off and I don't see it
ya I think it is. I tried your trick, however I could get the edge very good and just ended up hammering it in farther. Do you think I can push it out from the inside?
Not easily accessable from the inside.
I ended up trying to push it out from the inside.... I put a socket behind it then pryed it out with a beefy screwdriver. I was trying to save it to use over again. That didn't go so well so I drilled it then used a hook to pull it out.
I later bought the z10 plug which is worth the money.
Re: Endyn catch can removal, how to take of aluminum plug??? (tepid1)
ya I have another screw in there now. Its about 1/2" deep so i will see what can be done. I really appreciate the input, I am super frustrated right now. Smog was due last wednesay
is the plug completly inside of the hole? can you get ahold of 2 sides of it, and crush it (say with channel locks or something) that would make for easy removal
if its still sideways in the hole, try pryin it out with a prybar.
I finally got it out. I drilled it wide enough for a stock exhaust bolt, then got a crescent wrench and put the bolt through the plug and put the nut on via the bottom of the block. After that It took me about an hour of messing with it, once I got decent leverage it came right out
-8 hours of my life
-8 hours of my life
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack »</TD></TR><TR><TD CLASS="quote">I finally got it out. I drilled it wide enough for a stock exhaust bolt, then got a crescent wrench and put the bolt through the plug and put the nut on via the bottom of the block. After that It took me about an hour of messing with it, once I got decent leverage it came right out
-8 hours of my life</TD></TR></TABLE>
- half your brain cells
The z10 unit is worth the money after those 8hrs..... trust me mang.
Pick it up from dturd!
no I am done with this crap lol. Too much money and work for a college student
SOOOOOO much fun though, I drove my ls NA today. It was so slow that I thought something was wrong, but then I figured out nothing is wrong, it just is THAT slow.
You can't quit man, this is like the Mob...once your in there is no getting out.
I tried to quit myself but it didn't work out. Sold my CRX last year thinking I could get rid of it for good but now I have an EK...LOL
I live with the Motto, "If it ain't got **** or burn gas I ain't playing with it."
Good luck with what ever your doing.
Re: Endyn catch can removal, how to take of aluminum plug??? (CRX T-Si)
aha, but you might be wrong I am getting a YZ250F motocross bike and a 98+ BMW M Coupe (hardtop/hatchback) version of the M roadster in the next year. I want to go road racing and maybe some motocross races, instead of back road rally cross lol.
1 Post
this is why you shuld not be cheep and should have just got the z10 freze plug
they are very easyly removable
Re: Endyn catch can removal, how to take of aluminum plug??? (riceball777)
whats everyone talking about z10 for? lol, I haven't heard of the z10 yet and I actually got the Endyn because it was something I didn't want to cheap out on ha ha.
Ya the Z3 M coupes are nice, freakin goofy looking and I love it, they are really rare and look way different than anything else
meavey3368
07-12-2014 11:29 PM
shakeum
08-30-2010 12:48 AM
crxgator
29
07-17-2004 05:48 AM
