The End of my drag gen2 , final dyno plot :)
Old Oct 1, 2001 | 05:16 PM
Purelude's Avatar
Default The End of my drag gen2 , final dyno plot :)
Hello Everyone.
For those who have been keeping up with what i've done with the car over the year, then you know it hasn't been a fun trip.
Installing the drag 2 kit was a pain, but knowing that it didn't make the power i wanted was worse.
The 2nd installment of the epic turbo was the hondata system. This proved to be a worthwhile purchase, but the power was still not there. I had made only 214hp with a near perfect air ratio.
here is the dyno of the hondata tuned vs what drag supplied with me.
Not too great, but still a very nice increase in power. This is when i first experienced TIRE SPIN in first gear. Amazing yes.
Now jump forward a few months. I have been doing a lot of research on turbos, getting to know them like my own two feet. I figured that my turbo specs were all wrong for our cars. So i sent my turbo to get it rebuilt to some yummy specs. It was changed to a .63 A/R turbine, with a stage 3 to4B 50 trim (from a to4E). This was done at http://www.majesticturbo.com very nice ppl.
Let me tell you about why i changed turbos. I had thought that the turbine side was too small. I had thought that i had a .48 a/r. which is very very tiny and would explain the linear growth that you see from the dyno above. This was NOT the case. I had a .63 a/r in there! wowez me when i found out (majestic already had my turbo ). But theres more. What was in there before was the to4B super V wheel. This wheel is very big and laggy, and makes power past 10psi. Past 10psi is where most of us can't afford to run. So i went ahead and switched it to a to4e 50 trim. This wheel is very nice. capable of 350-450 hp, it is not so big, and makes good TOP END POWER from what majestic told me.
Now i bet you're dying to see what i got. well here it is. 9 months of being turbo'd and i finally got to where i want (90% satisfied).
This compares NA form w/ mods (type s cams, bolt ons) to the end result of todays work.
Very nice numbers. But you might be wondering what the dip is at 6k rpm? Well, my avc-r boost controller was acting very funny. At 6k rpm it let off 1psi of boost! bastard machine, i say. So, when it lost that 1psi, the whole system suffered and had to regain that 1psi (as you see it climbing up afterwards). sucks i know, but its a simple mechanical fix. in theory, if i get my controller working correctly so that it doesn't lose that 1psi, it should continue on strong.
Here is a plot comparing what drags fuel management gave me, what hondata gave me, and finally what the new turbo got me.
Interesting yes.
Some more interesting things
This is what the new turbo did just bolted on. first run of the day, and what we ended up with when we left.
Thanks for your time. It drives pretty nice now, muoy fun. and i feel that its the most i can get on stock internals. .54 bar is what i'm pushing so about 7-8psi.
You can check out all the dynos i have at http://rspec.net/purelude
Tim
Old Oct 1, 2001 | 05:25 PM
LsTurbo91's Avatar
Default Re: The End of my drag gen2 , final dyno plot :) (Purelude)
nice.. was this on 91 octane?
Old Oct 1, 2001 | 05:29 PM
DIRep972's Avatar
Smarter than you
very interesting.. 250hp will be fun though
knock on wood.. my turbo is goin on soon and of course i hope i make the power i am planning on making..
[Modified by DIRep972, 2:30 AM 10/2/2001]
Old Oct 1, 2001 | 05:34 PM
Purelude's Avatar
Default Re: The End of my drag gen2 , final dyno plot :) (9psiLsT)
yea 91 octane, fun for all!
and just in case you want to know what it looks like.
[Modified by Purelude, 6:41 PM 10/1/2001]
Old Oct 1, 2001 | 06:00 PM
98lude's Avatar
very nice!!
so what did you have to do to make that 50hp increase at top end? your a/f ratio seems pretty similar at top end, but you made so much more hp!!!
btw, what psi were you running at? nice job; sure gave me some hope on my car..
Old Oct 1, 2001 | 06:18 PM
falcongsr's Avatar
What is this crap?
no air filter?!?!
Old Oct 1, 2001 | 06:30 PM
dustin's Avatar
Default Re: The End of my drag gen2 , final dyno plot :) (98lude)
Did you not read his post? He spent quite a while explaining where the extra 50hp came from.
Dustin
Old Oct 1, 2001 | 06:38 PM
LsTurbo91's Avatar
Did you back off timing at all on the map?
Old Oct 1, 2001 | 07:19 PM
98lude's Avatar
Default Re: The End of my drag gen2 , final dyno plot :) (dustin)
Dustin:
I was refering to his last dyno sheet, where he compared his first run of the day and his last run of the day, both using the same turbo. with the a/f being pretty similar, I just wondered what he did to make the difference. Maybe there is something I am missing out?
Old Oct 1, 2001 | 07:27 PM
LsTurbo91's Avatar
that would be the previous turbo with the first dyno.
Old Oct 1, 2001 | 07:42 PM
Purelude's Avatar
at the beginning of the day, the avc-r didn't learn the boost curve. It actually did ok, but instead of losing 1psi, it lost 3psi. we couldn't get it to hold any steadier, sucks.
theres no air filter yet, because the new turbo had a bigger inlet. the filter is on order though.
Old Oct 1, 2001 | 07:45 PM
VaporTrail's Avatar
New User
I have to give you a lot of props. Most people would stop after the Hondata, but since you weren't satisfied, you took the proper steps to get to where you wanted to be. Excellent work, you earned my respect.
Old Oct 1, 2001 | 07:50 PM
dustin's Avatar
Dustin:
Ok, sorry. I am a jerk like 90% of the time
Dustin
Old Oct 1, 2001 | 09:22 PM
SIK IN DA HED's Avatar
New User
whut type of rims are those on your lude? are those the rotas?
Old Oct 1, 2001 | 10:06 PM
98lude's Avatar
dustin: thats okay; lost count of the number of times that you guys came through for me anyway.
purelude: so that is only it lost psi? hmm... hopefully, that is the same problem that I am having too.
Old Oct 1, 2001 | 10:37 PM
Purelude's Avatar
Yea, that 1psi we lost at 6k rpm hurt us that bad. It sucked. we couldn't combat it at all, we tried upping the boost that range, lowering it, upping the duty cycle, etc...no go..just made things crazy.
Old Oct 2, 2001 | 04:30 AM
DirtyLude's Avatar
Where do you have the boost line for the wastegate / boost soleoid hooked up to? The turbo port or at the plenum, like some people do?
Old Oct 2, 2001 | 06:48 AM
boomslang's Avatar
Default Re: The End of my drag gen2 , final dyno plot :) (DirtyLude)
Awesome, I am very happy for you. What stage wheel are you using?
Old Oct 2, 2001 | 06:50 AM
boomslang's Avatar
Default Re: The End of my drag gen2 , final dyno plot :) (Inlinefour)
One more thing, you NEED to wave that dyno in the faces of all the JRSC Prelude owners. It'll make them sick!
Old Oct 2, 2001 | 07:08 AM
Purelude's Avatar
Dirtylude -
the pressure source is right on the intake manifold. the avc-r uses this alone with no sharing. It's using the 3rd nipple on the intake. It's weird, the garret housing doesn't have a compression hole like my old one did, so i had to get creative w/ the hoses.
Inlinefour -
its a stage 3 wheel O yes, i will wave it around for those jsrc guys!
[Modified by Purelude, 8:15 AM 10/2/2001]
Old Oct 2, 2001 | 07:10 AM
Seraph0's Avatar
It's all in the turbo
One question tho that maybe I missed.
You said you HAD a Super-V and then went to a E.50. (Super-.50?). But what turbine wheel did u originally have? Sounds like you had a Stage1 (stock) turbine and then went to a Stage3?
Old Oct 2, 2001 | 07:13 AM
Purelude's Avatar
Default Re: The End of my drag gen2 , final dyno plot :) (MarkC)
the turbine was originally a stage 3 as well. i didn't feel good going into the dyno....especially after pulling 208hp on the first run, but hey, tuning is cool.
Old Oct 2, 2001 | 07:16 AM
ArizonaTurbo's Avatar
I am very surprised that the drag gen 2 kit came with the .48 housing, especially since you have such a big motor! I have a 2.0L and my fist turbo was .63 housing, stage III turbine, 57 trim .60 AR compressor (T3/T04E). The car would start building boost at 2800 rpms even with 8.5:1 CR and I would have full boost @ 3500 rpms! I then decided to go up to the .82 housing and it was killer. I still had full boost at 4400 rpms and once it spooled up, it was just nasty! I think you could make some serious HP if you go up to the .82 housing w/ Stage III turbine. You shouldn't worry about lag becuase you have higher CR than what I have and you have .2L of displacement more than what I have! I think you can make 300-325 easily to the wheels with no problems!!!!
teddy_dc2
Jan 5, 2006 07:45 PM
ochsy03
Jun 22, 2004 09:18 PM
TreLude
Jan 16, 2004 10:51 PM
GruvyTune
Nov 7, 2003 06:00 PM
