Electronic Boost Controller causing spike?
Old Mar 16, 2005 | 07:31 PM
2LiterTurboSeR's Avatar
Default Electronic Boost Controller causing spike?
Although I don't drive a Honda, I figure that some other turbo cars may experience the same problem that I am experiencing.
My car (200sx Se-r) is equipped with a t3/t04e (.50 trim, stage III wheel) turbo with an internal wastegate. I am using an AVC-R boost controller to handle the boost.
The problem I am experiencing is that whenever the vacuum lines for the boost controller are hooked to the turbo, no matter what boost level it is at, it spikes dramatically. Example: a boost spike when set at 10 psi, goes to 15 psi. No matter the weather, hot or cold.
When the vacuum lines are unhooked, I only experience creep when it is extremely cold. I ordered the GReddy T.V.V.C manual boost controller last night hoping that it will no longer spike.
Will this be a good solution or should I upgrade to a stronger wastegate actuator? HKS sells one, and I just don't have the money to upgrade to a new manifold, external wastegate and different intercooler piping.
Thanks for any input.
Old Mar 17, 2005 | 04:40 AM
beerbongskickass's Avatar
Default Re: Electronic Boost Controller causing spike? (2LiterTurboSeR)
Internal wastegates are known for creeping and spiking. I had pretty bad problems with mine when trying to boost over 10psi. I recently got a tial external wastegate and I no longer have any spiking or creeping problems.
Old Mar 17, 2005 | 07:45 PM
Default Re: Electronic Boost Controller causing spike? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Internal wastegates are known for creeping and spiking. I had pretty bad problems with mine when trying to boost over 10psi. I recently got a tial external wastegate and I no longer have any spiking or creeping problems.</TD></TR></TABLE>
Right now, I'm using a BlueBird manifold, which is a factory Nissan manifold from the JDM SR20det (FWD). Unfortunately, this manifold has a different configuration from aftermarket manifolds, which mount the turbo on top of the manifold. My manifold isn't configured for external wastegate either, and I am damn broke.
I was reading on another website that HKS makes an upgraded internal wastegate that is supposedly stronger than the original wastegates the turbos come with. Can anyone verify this?
playahwitgame
Sep 19, 2006 09:08 AM
camelian
Nov 22, 2004 01:51 PM
Meet07
Feb 3, 2004 10:45 PM
GDM Z28
Nov 30, 2003 06:13 AM
teamrocket si
Feb 10, 2002 02:27 PM
