Electric boost controller
Old Mar 10, 2006 | 10:45 PM
Avenged7x's Avatar
Default Electric boost controller
I installed a greddy profec type s in my FI integra. I have a 7 psi spring and is a drag gen3 kit. right now i don't see a difference in boost when adjusting it. i turned it all the way up and i still only hit about 4 psi around 5k rpm ( which is wat i was doing before installing the controller ) . I dont push my car pass that much since i havent had it tuned and i dont have all my gauges up. Searching around i found that my spring should be fine, so do i need to tune it first before seeing a difference? ive looked over the install guide alot and it seems to be installed correctly, any suggestions would be cool
Old Mar 13, 2006 | 05:06 PM
rdeezy78's Avatar
Default Re: Electric boost controller (Avenged7x)
what is the size of your down pipe and exhaust? You may be creating a lot of back pressure and 5k rpms is not enough flow to make more boost. Good luck
Old Mar 13, 2006 | 06:24 PM
DaveF's Avatar
Default Re: Electric boost controller (rdeezy78)
check over all of your intercooler piping connections. sounds like you have a leak. the drag setup should easily build 10 psi by 4500.
Old Mar 16, 2006 | 11:46 PM
Avenged7x's Avatar
Default Re: Electric boost controller (Dturbocivic)
i have 3 inch dp and exhaust. I checked one of my cuppling and there is a tear in it. I ordered new better quality ones and should get them in the next few days. Ill see if that fixes it but the tear wasnt to bad but will be looked into, not totally convinced that was the problem.
and when u say 10 psi by 4500, u mean full open throttle?
any other suggestions would be great
Old Mar 17, 2006 | 02:47 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Avenged7x &raquo;</TD></TR><TR><TD CLASS="quote">i have 3 inch dp and exhaust. I checked one of my cuppling and there is a tear in it. I ordered new better quality ones and should get them in the next few days. Ill see if that fixes it but the tear wasnt to bad but will be looked into, not totally convinced that was the problem.
any other suggestions would be great </TD></TR></TABLE>
yea wot. you should easily build 10psi/4500.
Old Mar 17, 2006 | 11:52 AM
Avenged7x's Avatar
I was starting to think it was my boost gauge since i ghetto rigged the vacuum to the gauge, but i read 20 vacuum at idle, which i believe is normal. Im buying a new intercooler since my drag one is getting old and banged up and ill look into more leaks. Thx for the responses
DOHC1.8
Oct 5, 2012 07:57 AM
turbo boost
Jul 29, 2009 09:23 PM
Blindstuff
Dec 22, 2004 06:16 PM
Quetzolcotl
May 24, 2002 01:30 AM
smoothludey2
Feb 25, 2002 02:39 PM
