EGT Problem!
Old Aug 5, 2006 | 02:35 PM
IntegraTypeR's Avatar
Default EGT Problem!
Hey guys,
i am in deep trouble....i took my manifold to get a bung welded to fit on the 3rd runner underneath the mani (hidden location)...and the garage made a mistake welding it in a wrong angle where it hits the turbo turbine and now whatever i do the turbo cant be bolted to the manifold anymore
what can i do now? i was thinking of bending where i marked green...is that possible? will it the sensor still work? will read accuratly? this is an EGT Defi D gauge model
let me know asap guys!
Km
Modified by IntegraTypeR at 10:01 PM 8/7/2006
Old Aug 5, 2006 | 03:18 PM
playahwitgame's Avatar
Default Re: EGT Problem! (IntegraTypeR)
take it back and tell them to fix their mistake
Old Aug 5, 2006 | 03:41 PM
B18EG6's Avatar
do you happen to know the type of the thermocouple in there? How many wires are coming off of the defi harness?
try this website, it may help
http://www.teamrip.com/accessories.html
Old Aug 5, 2006 | 03:56 PM
Default Re: EGT Problem! (B18EG6)
where the it plugs i can see two wires...one white and one red and it does show two, cause where it clips to shows two pins! does that help?
Old Aug 5, 2006 | 04:53 PM
B18EG6's Avatar
I dunno how much more I can help-
is the defi in degrees C or degrees F? My greddy has that wire, and it reads in degrees C. Perhaps you could contach Defi if you dont wanna fix the mani?
Old Aug 7, 2006 | 09:15 AM
Hey guys,
i took the manifold back to the garage to get this fixed and i knew they would ask me to redo it again (remove old bung, get manifold weld filled and put a new bung a different location)....well i said NO WAY I WANNA DO THIS TO A FULL RACE manifold and oh by the way i dont have another bung, so i worked with them instead of shouting at them, so i got an idea to work on the old bung and had to file the bung at a certain angle and still sensor can still go in without hitting bung thread walls (the bung diammeter is bigger then the sensor by the way...after that i realised that the bung threads got some weld on from last time (just noticed today), so the piece provided by Defi cant be used any more ( the one that has two different threads on both ends)...so i didnt loose hope and got that piece grinded and filed to be flush, then got that piece welded on the angled bung....and here is the result:
am happy that i can fit my turbo without putting any weight or pressure on the sensor anymore, but i do still have a question...does the clearance at that area seem to be ok in terms of heat? isnt the turbine heat gonna give me an inaccurate reading? i have a feeling the sensor will get both exaust heat and turbine temp? hope someone can clarify that am gonna be fine here?
Old Aug 8, 2006 | 09:03 AM
is the egt probe seem to be in deep enough?
Old Aug 8, 2006 | 10:34 AM
dpetro1's Avatar
everything looks good. thats a pretty creative way to fix the problem.
Old Aug 8, 2006 | 10:37 AM
mike1114's Avatar
Yours is perfect, your good to go.
I had to bend mine some cause it hit my turbo on my FR mani, and it worked just fine..
THen it got even harder for me, I bought a new egt gauge and it had a thicker probe than the previous one. I had to drill out the brass fitting I have threaded into my mani (i don't have a bung welded) and it was a bitch as that fitting isn't very big.
Old Aug 8, 2006 | 10:44 AM
Default Re: EGT Problem! (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">everything looks good. thats a pretty creative way to fix the problem. </TD></TR></TABLE>
thanks for the compliment and appreciate your comment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">Yours is perfect, your good to go.
THen it got even harder for me, I bought a new egt gauge and it had a thicker probe than the previous one. I had to drill out the brass fitting I have threaded into my mani (i don't have a bung welded) and it was a bitch as that fitting isn't very big.</TD></TR></TABLE>
thanks for the info and hope your setup is good for ya now!
thanks to HT members
Old Aug 8, 2006 | 02:59 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
why woul you put it up stream of the turbo?
what are you going to do when the tip decides to melt off and go throuh your turbine?
i would risk geting a slightly low reading versus risking a gt turbo
Old Aug 8, 2006 | 03:30 PM
dpetro1's Avatar
Default Re: (BrokeAssWhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">why woul you put it up stream of the turbo?
i would risk geting a slightly low reading versus risking a gt turbo </TD></TR></TABLE>
i have always been under the impression that egt probes should be located 2" from the head on the #3 runner for hondas. right where this guy has it. i dont think you should have to worry about an instrument made for measuring exhaust temperatures melting...but i dunno.
Old Aug 8, 2006 | 05:00 PM
mike1114's Avatar
Default Re: (dpetro1)
don't listen to him it should be where yours is.
Old Aug 9, 2006 | 10:02 AM
Default Re: (mike1114)
hehe ok thanks again guys
rich7777
Feb 14, 2011 12:11 AM
nick91civicsi
Sep 5, 2006 03:23 PM
cokex
Oct 19, 2002 06:42 PM
uneekcrx
Sep 8, 2002 07:59 AM
Crxlsturbo
Aug 5, 2001 01:05 PM
