egt mounting question
Old Aug 15, 2004 | 04:43 PM
  #26
wantboost's Avatar
Who is Mr Robot?
Default Re: (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">i put mine in the DP
I like that idea, what are the pro's and cons compared to mounting it on the 3rd runner? One pro i can see is it gives you the cumulative exhaust gas temp entering the turbo.
Old Aug 15, 2004 | 06:33 PM
  #27
LostSolVTEC's Avatar
Default Re: (wantboost)
i have mine mounted 3rd from the timing belt, i'll see if i can get a pic
Old Aug 16, 2004 | 12:10 AM
  #28
playAho's Avatar
Default Re: egt mounting question (wantboost)
thanks just checking
Old Aug 16, 2004 | 05:06 AM
  #29
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
I like that idea, what are the pro's and cons compared to mounting it on the 3rd runner? One pro i can see is it gives you the cumulative exhaust gas temp entering the turbo.</TD></TR></TABLE>
Well the #3 cylinder is known to run the leanest out of the four. From a tuning and accuracy standpoint, this is actually more of a downfall of the location.
A pro of the location is that if for some reason the probe breaks off or anything, it will not harm the turbo.
Old Aug 16, 2004 | 05:14 AM
  #30
it runs the hottest due to the fact that the heat from cylinders 2 and 4 are retained and transfered into number 3 causing it to run the hottest. This extra heat causes that cylinder to creat a little more power with the heat, but also the most dangerous combustion situation. Most people put the EGT probe there to moniter the worst case scenario
that's the information that i got from boosted-hybrid when i asked him
jarhead90crx
Oct 14, 2011 06:01 PM
djnikko
Jul 7, 2004 07:16 AM
civictypenos
Oct 4, 2002 01:55 PM
revhrdls
Aug 31, 2001 08:43 PM
