Eg Greddy Kit boost question?
Old Jan 16, 2008 | 11:43 PM
abourmaian's Avatar
* B A N N E D *
Default Eg Greddy Kit boost question?
I just got the greddy kit from a friend for my 93 hatch and i wanted to know how would i adjust the boost on the internal wastegate. Would I need to get a boost controller or do i just adjust the actuater rod?
Old Jan 17, 2008 | 09:02 AM
SpoolnG2's Avatar
Default Re: Eg Greddy Kit boost question? (abourmaian)
You need a boost controller
Old Jan 17, 2008 | 09:19 AM
1Jackleg's Avatar
Default Re: Eg Greddy Kit boost question? (SpoolnG2)
You can raise the boost by adjusting the actuator arm, however it would be better to just get a boost controler. I think you can get the turbo xs manual controlers for under $100.
Old Jan 17, 2008 | 01:01 PM
abourmaian's Avatar
* B A N N E D *
Default Re: Eg Greddy Kit boost question? (1Jackleg)
I know the kit is pre set at 5 pounds. How mutch HP do you think i will make with a bone stock d16z6 at 5 pounds. also how much do you think i can safely boost with a bone stock motor. (No injectors, fpr, no mods)
Old Jan 17, 2008 | 07:41 PM
bretthuff0's Avatar
Get the fuel system before you start getting boost happy.
Old Jan 18, 2008 | 08:27 AM
abourmaian's Avatar
* B A N N E D *
Default Re: Eg Greddy Kit boost question? (bretthuff0)
Ok I wanted to boost about 7 psi. What would i need in order ro do that on a stock motor?
Old Jan 18, 2008 | 09:22 AM
bretthuff0's Avatar
A boost controller manual or electronic. It depends on how much money you want to spend.
Old Jan 18, 2008 | 11:41 PM
ridin98civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abourmaian &raquo;</TD></TR><TR><TD CLASS="quote">Ok I wanted to boost about 7 psi. What would i need in order to do that on a stock motor?</TD></TR></TABLE>
sounds about like me. luckily i upgraded injectors and fuel pump, because as soon as i got 7 i wanted more. im now sitting on 10 and am itching to turn it up.
Old Jan 19, 2008 | 07:54 PM
abourmaian's Avatar
* B A N N E D *
Default Re: Eg Greddy Kit boost question? (ridin98civic)
What size fuel injectors did you get and how many pounds was your fpr set to?
Old Jan 19, 2008 | 08:22 PM
i have lucas 440's and i dont have an aftermarket FPR. i am using a crome tuned p28
Old Jan 20, 2008 | 10:16 PM
abourmaian's Avatar
* B A N N E D *
so in order for me to boost 10 psi i only need to get 440's, boost cont., and a tune?
Old Jan 21, 2008 | 11:02 AM
2000siturboR's Avatar
im pushing 7 pounds without a boost controler same kit but for an em1. so u can adjust it for slightly high psi. thats about it on these turbos
avotegra
May 22, 2007 12:31 PM
my93hatch
Apr 30, 2005 07:33 PM
CAE
Mar 3, 2005 02:40 PM
incognitoracerr
Apr 23, 2003 06:52 AM
mrod006
Dec 2, 2002 07:33 PM
