Easy Wastegate ?
Old Jun 4, 2008 | 06:26 PM
accord99power's Avatar
Default Easy Wastegate ?
if my WG is 7 psi spring then is 7 psi my max or min i can boost?
Old Jun 4, 2008 | 06:33 PM
got wide's Avatar
Default Re: Easy Wastegate ? (accord99power)
max if you dont have a boost controler, min if you do
Old Jun 4, 2008 | 07:54 PM
HiProfile's Avatar
So you're installing your turbo kit yourself, and you never knew this? You've NEVER looked into the Forced Induction Forum FAQ!???
I'd hate to be your car at this point
Old Jun 4, 2008 | 08:16 PM
Rickdrizzle's Avatar
Default Re: Easy Wastegate ? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">So you're installing your turbo kit yourself, and you never knew this? You've NEVER looked into the Forced Induction Forum FAQ!???
I'd hate to be your car at this point </TD></TR></TABLE>
zing!
Old Jun 6, 2008 | 06:14 AM
ohhh geez another one of you guys SEARCH, FAQ, blah blah, its alot faster to get an answer then to look up broken links
Old Jun 6, 2008 | 06:20 AM
twkdCD595's Avatar
minimum. although you could see slightly more or less than 7psi without a boost controller depending on the setup and your vac source.
Old Jun 6, 2008 | 06:31 AM
Default Re: Easy Wastegate ? (twkdCD595)
thanks tweak hey there was a oring that mated with the exahuast manifold to the WG it was a steal like oring, was i suppose to use it? theres a tiny gap but im guessing the oring seals it up?
Old Jun 6, 2008 | 02:34 PM
twkdCD595's Avatar
you mean that? if so yes you need that to properly seat the gate/ valve to your manifold.
image borrowed from tials website, hope you dont mind guys.
Old Jun 7, 2008 | 05:43 AM
yah thats exactly it thanks twkdcd595, i couldnt get mine to sit flush on the flanges and its torqued down pretty tight, its really close but i think the flange started warping so i stoped, seamed to have a tight seal though.
Old Jun 7, 2008 | 07:25 AM
Flashmn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">its really close but i think the flange started warping so i stoped, seamed to have a tight seal though.</TD></TR></TABLE>
It should be fllange againt flange flat.
Old Jun 8, 2008 | 07:16 AM
Flashmn's Avatar
Default Re: Easy Wastegate ? (transpro)
No you're wrong. If you dont have a boost controller, you have one hose running to it, thats the boost reference that opens the wastegate port.
With a manual boost controller, well its the same, except you alter the reference signal.
With an electronic boost controller, you have a hose going to the top side that counters the pressure in the wastegate, which then alters the amount of boost and characterstic how the boost raises.
Nothing to do with switching hoses and switching hoses is most likely going to cause you engine damage.
Old Jun 8, 2008 | 09:33 AM
transpro's Avatar
Default Re: Easy Wastegate ? (Flashmn)
I dunno, I just called my boy that works there and he said you can definitely move the hose around and get different boost pressure.
Check out page 8
http://www.synapseengineering....l.pdf
Old Jun 8, 2008 | 12:24 PM
Flashmn's Avatar
I dunno about synapse... no experience with it.
Old Jun 8, 2008 | 12:59 PM
deucedeuceEK's Avatar
Yes, with a Synapse you can control boost levels without a boost controller
Old Jun 8, 2008 | 06:41 PM
RedneckRicer's Avatar
anyone notice how transpro all his responses are in regards to wastegates and supporting synapse i wonder if peter is making a comeback again..lmao
Old Jun 9, 2008 | 05:56 AM
TiAL's Avatar
Default Re: (RedneckRicer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedneckRicer &raquo;</TD></TR><TR><TD CLASS="quote">anyone notice how transpro all his responses are in regards to wastegates and supporting synapse i wonder if peter is making a comeback again..lmao</TD></TR></TABLE>
It is Peter...he's not very good at 'blending in'
mods have been made aware, he should have another vacation coming up
Old Jun 9, 2008 | 08:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">ohhh geez another one of you guys SEARCH, FAQ, blah blah, its alot faster to get an answer then to look up broken links </TD></TR></TABLE>
unfortunately he is right, these questions are answered many times before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deucedeuceEK &raquo;</TD></TR><TR><TD CLASS="quote">Yes, with a Synapse you can control boost levels without a boost controller </TD></TR></TABLE>
you can do that with a turbonetics also, but it doesnt make it consistent.
to answer the op question, with a boost controller, the general rule is you can adjust no lower than the spring, and 2-2.5 times the spring on the high side.
rosco
Jun 21, 2006 07:40 PM
hatchracer02
Jan 10, 2005 05:13 AM
hatchattak
Mar 9, 2004 02:15 PM
nd8ch
Aug 26, 2003 04:47 AM
