dyno session at inline pro
Old Jun 23, 2004 | 10:16 AM
  #26
badCRX's Avatar
New User
Default Re: dyno session at inline pro (mildly interesting)
do your eyes water when you start the car in the garage!
I would guess that part of it is the lower compression pistons. If your goal was just 15psi, you probably should have stuck with stock compression pistons. I would try and find a way to get some of that compression back to help boost up the power and torque.
Old Jun 23, 2004 | 11:12 AM
  #27
2000turbosi's Avatar
Default Re: dyno session at inline pro (2000turbosi)
my goal was somewhere btw 350-400 on 93-94octane....just trying to figure out what to do next...(bigger intercooler, etc)...but apparently thats not a necessary since it can hold 400-450whp...i said 15psi because i thought i might be able to hit my hp goals with my setup...like i said right now its tuned for 12lbs...
Old Jun 23, 2004 | 11:40 AM
  #28
Silversupragirl's Avatar
I can't believe people are still being taken (I mean tuned ) by Inline. One question though... When John told you the Drag IC was insufficent, was he holding another IC that "just happend to be in stock"?
Old Jun 23, 2004 | 01:14 PM
  #29
alpha's Avatar
450 miles on a new bottom end isn't much. Over time you will see better numbers but I would still up the boost to see your goal is met.
Old Jun 23, 2004 | 01:32 PM
  #30
TurboJesse
Guest
Posts: n/a
Default Re: dyno session at inline pro (0x64)
LS Crank? i would expect more tq...numbers seem pretty weak for 12psi (no offence)
black_ek
Mar 7, 2007 06:07 PM
2000turbosi
Jan 29, 2006 01:05 PM
alfee
Jan 28, 2006 05:25 PM
19sec beast
Jun 1, 2005 04:30 PM
xrtdac
Oct 24, 2003 11:45 PM
