HELP: sitting on dyno how much boost?
Old Oct 24, 2003 | 09:19 PM
xrtdac
Guest
Posts: n/a
Default HELP: sitting on dyno how much boost?
NO bullshit please I need to know some honest stuff here.
AF is good: no higher than 12.5 and we are on C16 VPfuels race gas.
Current boost 25PSI
hitting 376HP and 361lb-ft
This is an LS motor with golden eagle sleeves, wiseco pistons, eagle rods, arp head studs, polished crank, balanced motor, cometic head gasket.
Drag Gen 3 turbo kit with drag intercooler and t3/to4e 50 trim 63 AR. turbo.
Can I go to 27 or 28 you think?
Old Oct 24, 2003 | 09:24 PM
xrtdac
Guest
Posts: n/a
Tuned on Hondata, golden eagle said I was good to 40 but am only shootin for 28.
Old Oct 24, 2003 | 09:31 PM
xrtdac
Guest
Posts: n/a
Old Oct 24, 2003 | 11:39 PM
Double121's Avatar
Default Re: (xrtdac)
If it were me I would stay where your at. If your wanting more power I would get a sc61 turbo and you could run the same hp probably on less boost. But thats just me and what I would do.
Old Oct 24, 2003 | 11:45 PM
xrtdac
Guest
Posts: n/a
I got to 395HP to the wheels and 376ft-lb torque. It was 70 degrees in the dyno area and we don't have any good fans for the intercooler. So basically we could hit 400 on the same boost if the dyno were outside and in the cooler air with good fans to give true simulation of power.
JDeez_1212
Aug 26, 2012 12:34 PM
masterEF
Nov 10, 2009 05:56 PM
97hb
Feb 28, 2009 05:22 PM
xrtdac
Oct 27, 2003 12:57 PM
SpeedMonkeyRacing
Apr 1, 2003 05:36 PM
