dyno results
Old Dec 2, 2001 | 03:00 PM
supersonic-rs's Avatar
Default dyno results
I finally got my dyno runs in.
I recalibrated my greddy profec-b my boost controler the night before. I set it 7 psi low and 9psi high.
green 6-7psi( on the way home from the dyno it was between 6-7 psi??)
red 9psi
blue 10psi
my set up is a dragIII kit stock internals, 2.5" mandle bent exhaust high flow cat, (dump tub retuned back into exhaust) extack muffler, neuspeed ignition. 94 octane in the tank.
so how does it look guys.. it is about what I expected .. I did knowtice the dip @ 4000 rpm?? not sure what to make of it!
[Modified by supersonic-rs, 4:02 PM 12/2/2001]
Old Dec 2, 2001 | 03:04 PM
D-SPEED's Avatar
Default Re: dyno results (supersonic-rs)
torque
Old Dec 2, 2001 | 03:14 PM
10 psi video.. my friend is hosting it
not to bad for a 98 rs
http://www.myxr4ti.com/Ford%20Focus/...SR%2010psi.WMV
hope that works
Old Dec 2, 2001 | 03:35 PM
stick's Avatar
good #'s
Old Dec 2, 2001 | 04:20 PM
quikrpm'z's Avatar
try to look at the a/f ratio , at 4000 rpm. that should explain it.
Old Dec 2, 2001 | 05:08 PM
jbsadler's Avatar
New User
Default Re: dyno results (quikrpm1)
Old Dec 2, 2001 | 05:20 PM
b18b98's Avatar
slap those slicks on and get those 12 second timeslips
Old Dec 2, 2001 | 09:17 PM
unfortunately they didn't hook up a a/f. it was a end of season promotion they had.. 3 pulls for $40.00/ canadian!.. I just wanted to get some base line runs.. I am thinking it is my ignition.. I may put the stock ignition back in and re-dyno it this spring..
Old Dec 3, 2001 | 09:31 AM
Default Re: dyno results (b18b98)
I plan on slapping a set of slicks on this spring, I am hoping for high 12's
Old Dec 3, 2001 | 01:43 PM
98Psi ITR's Avatar
damn that's cheap. we have had a dyno-drag here, since there is no track. 50usdm for 3 runs, but you get the wide band.
Old Dec 3, 2001 | 07:50 PM
degradated's Avatar
New User
Do you have an RS or a GSR?
You have a lot of torque and pretty good hp....I'm jealous, lol.
Old Dec 3, 2001 | 10:02 PM
InfamousDX's Avatar
Default Re: dyno results (degradated)
98 RS... he said before.
Old Dec 4, 2001 | 07:04 AM
RS..
thanks guys.. I am pretty happy with my car and it results..s
Old Dec 4, 2001 | 10:55 AM
degradated's Avatar
New User
Default Re: dyno results (InfamousCivic)
oh...woops, didn't see that. I was confused because the video clip link had "Jeff%20Turbo%20GSR" in it....
Old Dec 4, 2001 | 10:57 AM
degradated's Avatar
New User
Have you done any tuning at all, or is the just the car in it's beginning, bolt-on kit stages?
Old Dec 4, 2001 | 02:07 PM
my drag III has been oin for 6-8 months.. stock internals.. I plan on some tunning in the spring.. but so far I am very vey happy with it! :D
hdsupercrewf150
Honda S2000
34
Jun 23, 2007 07:51 PM
urbansi
Aug 8, 2005 04:23 PM
eg_nezay
34
Oct 25, 2003 09:15 AM
Arturbo
Oct 30, 2002 08:34 PM
austrian type-R
Jan 21, 2002 09:29 PM
