Dyno results
Old Dec 2, 2001 | 09:28 AM
GSRwBOOST's Avatar
Default Dyno results
252whp / 185 lbs torque @ 10psi
on order are 370cc injectors and vortec fmu calibration kit
did I do any damn good?
should I be happy?
I have had no tuneing what so ever.... not that I have much to tune anyway..
Old Dec 2, 2001 | 09:32 AM
HX_Guy's Avatar
Default Re: Dyno results (GSRwBOOST)
Jake your gonna have the turn the fuel pressure way down for when off boost or you will run way rich. Or get an AFC if you dont have one.
Old Dec 2, 2001 | 09:35 AM
stick's Avatar
i thought u had a built motor? i would expect more
comments??
flamencoT put 256/181 at 8 psi on stock everything on his GSR and that was not to redline
Old Dec 2, 2001 | 09:39 AM
HX_Guy's Avatar
Default Re: Dyno results (stick)
If Flemenco T has a stock GSR..then his compresion is 10.2:1 right? Jake is running 9.0:1 so that is why he put down similar numbers at 2 more PSI.
Old Dec 2, 2001 | 09:47 AM
FAST94GSR's Avatar
New User
Default Re: Dyno results (HX_Guy)
what's your af ratio do you have a plot of that. that looks a little weak.
Old Dec 2, 2001 | 10:03 AM
GSRwBOOST's Avatar
Built yes.. tuned no.
Yes my compression is 9-1 so I guess you could expect a slight loss.
I was thinking that my air filter was too small (came w/ drag kit), the air filter pipe I was told was hot to the touch and should be plastic to keep heat down, that i need injectors to crank up the boost, and a bunch of tuning once those are in.
I guess you could say I'm slightly dissapointed, but considering all the factors involved, i can't complain too much.
My engine is fully built, but I have no real fuel/timing solution and right now I cannot justify the cost of a hondata and tuning. perhaps later down the road once the bills are paid off.
Old Dec 2, 2001 | 10:53 AM
IM ALL BOB's Avatar
Sup Jake.. it's Bob..well it was a good run.. and yeah like u said it may be built but no tuning whatso ever.. I talked to chris e at autolink and he was like tell jake to turn it up to 50psi =x j/k well good run..let's all thanks ryan for pulling this thing together for us little people
Old Dec 2, 2001 | 11:55 AM
stick's Avatar
GSR stock c/r is 10.0:1
but i was really expecting more for 10 lbs of psi even tho his c/r was 9:1
Old Dec 2, 2001 | 12:00 PM
Tomakit's Avatar
what fuel sys are you running?
12:1 and stock injectors?
Tom
Old Dec 2, 2001 | 12:20 PM
DIRep972's Avatar
Smarter than you
comments??
stan made those numbers at 6.5psi FYI
Jake-#'s are definitly a bit low.. definitly think about getting a system to seriously tune it and it will definitly be worth it..
Old Dec 2, 2001 | 01:32 PM
degradated's Avatar
New User
Default Re: Dyno results (DIRep972)
Jeff did all the pulls yesterday in 3rd gear. Don't you think the numbers would be automatically low because of the not-close-to 1:1 gear ratio, unless it was corrected by his computer?
Old Dec 2, 2001 | 01:33 PM
degradated's Avatar
New User
Default Re: Dyno results (degradated)
Jake, put up your damn dyno sheet...I wanna see it again. Or send it to me. Did you get the videos I sent you? Wait, you won't be able to check until Monday since you are getting these at work.....oh well, let me know.
Old Dec 2, 2001 | 04:42 PM
jbsadler's Avatar
New User
comments??
ouch....another gut punch.......i guess you can't mess with Texas
Old Dec 2, 2001 | 04:47 PM
Rob03Pro5's Avatar
comments??
SenekaGSR made 261whp/190ft/lb at 6psi (5.8 w/ TiAL) and we didn't take it to redline cuz his tach is off. http://www.geocities.com/b_real45/IntegraGSR.html
Old Dec 3, 2001 | 11:22 AM
PROFILES2000's Avatar
Default Re: Dyno results (Rob92SC)
tune the fuel a little then go back (and play with the boost a little ) anyway good luck
lugnuts
Sep 9, 2010 08:59 AM
graphic
Sep 20, 2003 02:04 AM
Andrew 825SM
Oct 14, 2002 10:16 PM
HybridCoupe
Jul 16, 2002 12:07 AM
