Dyno of B18C1
Old Jun 30, 2004 | 07:26 AM
93H22ACX's Avatar
Default Dyno of B18C1
Dont currently have the dyno sheet...will post soon though....
My uncle (owner of Import Source)....just finished rebuilding a B18C1 with crower rods, JE pistons, JG IM, JG Throttle body, Type R LSD in a GSR Tranny, T60-1 turbo, Skyline FMIC, Custom IC pipe by him, SS CHROME MANIFOLD (WHO SAID A $200 MANIFOLD CAN'T BE GOOD?), Delta Race gate, and 1000cc injectors with Hondata S200. All this is in a 92 CX hatch weighing in at 2200lbs with him in it and SAME STOCK AXLES FROM 4 YEARS AGO!
Balanced performance in GA tuned it in 1 hour (short on time) and made 480whp and low 300wtrq on 20psi with a A/F ratio in the 11's, base was 350whp if i remember correctly. The tunning was done only a few short hours after the car started up and checked for leaks.
Break in time= 25miles
Runs perfect, he has about 500miles right now and still pulls hard as hell
First run with MT 24" slicks was 11.4@126mph with a burnt clutch master stage 5 clutch (had it for 5000 miles of hard racing). He was also asked to not race because he did not have a roll cage.
Now a roll cage and brand new stage 5 clutch is in. Next race will be up in TN for the Nopi Drag wars. New times will be posted up also......
Old Jun 30, 2004 | 07:58 AM
Egg-weezy's Avatar
Default Re: Dyno of B18C1 (93H22ACX)
With the T60-1 at that boost level when you start to see spool?? When do you hit full boost?? Happy with the turbo choice??
Some nice numbers.
Old Jun 30, 2004 | 08:07 AM
93H22ACX's Avatar
Default Re: Dyno of B18C1 (MidoriHB)
the turbo has a .70 a/r....
i believe full boost is like 4000 or so...cant remember but i'll ask him. He likes it! All hell breaks loose once you hit 6000rpm though
Old Jun 30, 2004 | 08:28 AM
m R g S r's Avatar
Full boost 4krpm's? What size pistons you using?
Old Jun 30, 2004 | 08:34 AM
93H22ACX's Avatar
Default Re: Dyno of B18C1 (m R g S r)
20 over....i will have to ask him when full boost hits...i'm pretty sure it is some where between 4-4.5k
Old Jun 30, 2004 | 09:07 AM
93H22ACX's Avatar
correction..........
Full boost of 18psi@5500rpm starts to boost at 3000rpm on the T3/T60-1
Old Jun 30, 2004 | 09:15 AM
11psiTurboSI's Avatar
Nice #'s
Old Jun 30, 2004 | 09:22 AM
Turbocivic94's Avatar
Default Re: Dyno of B18C1 (9psiTurboSI)
Nice #'s
Old Jun 30, 2004 | 09:25 AM
93H22ACX's Avatar
Default Re: Dyno of B18C1 (Turbocivic94)
i've posted his car before...but here it is again:
http://www.we-todd-did-racing....DE%3D
CptCorN
22
Feb 17, 2008 07:03 AM
mtber
Mar 1, 2006 01:29 PM
turbochargeb18c
Jul 28, 2005 02:31 PM
seen4ever
Nov 22, 2004 09:04 AM
slowsi00
Nov 17, 2002 11:34 AM
