dump tube question, help!!!
Old Dec 10, 2003 | 01:05 AM
BoOsTiN Dc2's Avatar
Default dump tube question, help!!!
ok heres my question... i have a drag gen 3 manifold and the wastegate is near the timing belt side, also my turbo inlet is facing the driver side wheel... i was wondering if i made a dump tube where the AC fan use to be but after the turbo inlet and before the oil pan... maybe a lil further down then the oil pan or the same height as the oil pan (measuring from the ground). the question is will i have any problem with the heat of the external wastegate dump tube being so close to the turbo?? the wastegate will open at full boost and the car will be moving fast and the air will be pushing the air coming out of the dump tube to the back of the car... hope you guys understand what im saying... sorry if i didnt make myself that clear... what i mean is its almost like the side exit dump tube coming out to the side of the front bumper but instead having it go straight down but mayb 2-3 inch away from the turbo and 2-3 inch away from the oil pan... thanks in advance...
Old Dec 10, 2003 | 10:38 PM
Default Re: dump tube question, help!!! (tRaCeBuStAbUsTeR)
ttt
Old Dec 10, 2003 | 10:58 PM
RedStarGsr's Avatar
ugh.......... i am so confused.
Old Dec 11, 2003 | 01:18 AM
basicly what i mean is between the oil pan and the turbo inlet is it ok to have the wastegate dump tube there between those two?
Old Dec 11, 2003 | 06:20 AM
b16ahybrid's Avatar
Default Re: (tRaCeBuStAbUsTeR)
I have the same manifold. My dump tube exits just below the oil pan. It goes strait out towards the front of the car, turns down just past the turbo and then one it clears the turbo it curves back toward the rear of the car. The opening is just below the oil pan
Old Dec 11, 2003 | 06:32 AM
30psi Teg's Avatar
Default Re: (b16ahybrid)
youll be fine if your that worried about it just header wrap it.
Old Dec 11, 2003 | 07:58 AM
xenocron's Avatar
Default Re: (30psi Teg)
Will the exhaust from the dump tube get sucked in by the turbo?
Old Dec 11, 2003 | 09:29 AM
30psi Teg's Avatar
Default Re: (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Will the exhaust from the dump tube get sucked in by the turbo?</TD></TR></TABLE>
not if it is as low as the bottom of the oil pan or lower
Old Dec 11, 2003 | 07:06 PM
ok... thanks for the help... because i was thinking would it really matter?? cuz when the dump tube opens up the car will be moving, and the velocity will be pushing that air towards the back of the car
ek98gsr
Feb 6, 2015 10:56 PM
xASAPx
Southeast (Sales)
Dec 21, 2008 03:07 AM
Turbo-GSR1287
Jun 23, 2008 08:15 PM
92JDMSiR
Apr 27, 2002 04:39 AM
