DSM injectors question
Old Jan 6, 2003 | 09:14 PM
wrXtian's Avatar
Default DSM injectors question
ok i been searching for some for quite some time now and finally i went to kragen and asked if i could get some fuel injectors from a 1990 eclipse gsx. what they have aren't the actual factory fuel injector.. it's some other company.. i'm just curious if this would work in my integra.. as would they fit?? i'd assume they should plug in fine.. but i just wanted to ask before i spend $85 on this.
btw i have a 1990 integra LS
thanks
Old Jan 6, 2003 | 09:19 PM
Flamenco-T's Avatar
Default Re: DSM injectors question (xjdm94x)
if it is for DSM then it will fit on your teg...you may need a B16 injector grommet, but I have install them before without it..
stan
Old Jan 6, 2003 | 09:37 PM
wrXtian's Avatar
Default Re: DSM injectors question (Flamenco-T)
can i use my ls grommets?
Old Jan 6, 2003 | 09:39 PM
Flamenco-T's Avatar
you should, I have had some occasion where they will snuggle perfectly, there were times I had trouble getting them in...
also use oil or wd40 when you're putting them on...it makes it a lot easier and you won't tear the grommet
stan
Old Jan 7, 2003 | 07:33 AM
wrXtian's Avatar
since i have a 1990 my stock injectors are peak and hold and the car comes stock w/ the resistor pack.. there isn't any custom wiring or anything i will have to do with these injectors right? technically i should be able to put them in and connect them just how the stock injectors were and it should work ok, right?
Old Jan 7, 2003 | 09:04 AM
gtcali's Avatar
Need something to tune down the injectors. ie Hondata, vafc, smc, etc.
Old Jan 7, 2003 | 09:57 AM
fsp31's Avatar
Your resistor pack will work fine, but like gtcali said, you'll be running hellacious rich without some way to compensate for the larger injectors.
Old Jan 7, 2003 | 03:00 PM
wrXtian's Avatar
Default Re: DSM injectors question (fsp31)
yeah i have a apexi AFC i wanna run the afc hack.. so basically the injectors i can get are the 1990-1999 eclipse turbo injectors?
Old Jan 7, 2003 | 03:33 PM
Flamenco-T's Avatar
yes, any slow turbo eclipses
wmac547
Engine Management and Tuning
Apr 8, 2014 06:43 PM
mrx
Dec 18, 2004 03:57 AM
4rcefeddeceiver
Jan 6, 2004 05:23 PM
Adriano
Oct 15, 2002 06:53 PM
