dsm injector install not running right
Old Mar 19, 2009 | 08:15 PM
ITR.#1446's Avatar
Default dsm injector install not running right
I went off of the threads in the faq section and went to radio shack, got 4 10 watt 10 ohm resistors, wired one resistor on each yellow and black wire for each injector. I turned the key forward and you can hear the injector spraying fuel, sounds like alot, then i started it up and tried to barely drive it but its obviously getting way way too much fuel. So what did i do wrong here? Car is a 00 si with a phearable chipped p28, stock ls motor, and a turbonetics turbo kit on 10 psi.
Old Mar 19, 2009 | 08:31 PM
93turbo16's Avatar
Default Re: dsm injector install not running right
Is the ecu programed to run the 450cc injectors?
Old Mar 19, 2009 | 08:45 PM
ITR.#1446's Avatar
I was told that it was from the person i got it from but i am starting to think its not.
Old Mar 19, 2009 | 09:38 PM
mtber's Avatar
Take the car to a local honda/acura tuner & have the car inspected & tuned using a chipped obd1 ecu running hondata, neptune, ectune etc.
ocracing973
Engine Management and Tuning
Nov 7, 2009 04:34 AM
turbosol18
Sep 2, 2007 07:40 AM
MBlake55
13
Aug 18, 2007 08:41 AM
