injector install question
Old Sep 1, 2007 | 09:10 PM
turbosol18's Avatar
Default injector install question
i put in my dsm 450cc injectors and started it up on stock p06 to make sure there wasnt any leaks and it idles weird, could this be due to the ecu not reading the 450cc?
Im waiting on my ecu to come back chipped and w/ the basemap to try it out then.
Old Sep 1, 2007 | 09:43 PM
turbosol18's Avatar
Default Re: injector install question (turbosol18)
anyone?
Old Sep 1, 2007 | 09:46 PM
DAneronimo's Avatar
yes, you're ecu thinks that there are still teeny tiny stock injectors in there, so the injector pulse is the same when it needs to be MUCH MUCH shorter since you're dumping twice as much fuel in there. dont run it until its tuned; you will hurt your motor. there is such a thing as too much fuel. good luck
Old Sep 1, 2007 | 09:51 PM
turbosol18's Avatar
Default Re: injector install question (DAneronimo)
thanks for the quick reply
really cant wait till my ecu comes back
Old Sep 2, 2007 | 04:48 AM
NVturbo's Avatar
O.G. triple O.G.
did you install a resistor box...? If not, you will need one. DSM injectors are low-impedance while delSol's and 92-up Civcs/Integras came with high-impedance injectors.
Old Sep 2, 2007 | 07:40 AM
turbosol18's Avatar
Default Re: injector install question (NVturbo)
yes i installed the in-line 10watt 10 ohm resisters
toeknee360*
Sep 26, 2005 10:09 PM
evilcivilian
Oct 6, 2004 10:04 PM
MintFlavored
Nov 2, 2002 07:30 PM
Pinhead
May 27, 2002 07:42 AM
paulzy
Jul 16, 2001 09:48 PM
