DSM 450cc injectors
Old Feb 5, 2006 | 10:24 AM
specscow's Avatar
Default DSM 450cc injectors
what all do i have to do to run DSM 450cc injectors on my 94 civic DX
do they just plug in do i have to buy something to control them?
thanks
Old Feb 5, 2006 | 10:28 AM
specscow's Avatar
Default Re: DSM 450cc injectors (specscow)
any one know anything about it?
Old Feb 5, 2006 | 10:33 AM
slow_redcivic's Avatar
do you already have the injectors?
Old Feb 5, 2006 | 10:39 AM
specscow's Avatar
Default Re: DSM 450cc injectors (slow_redcivic)
what else will i have to do to make them work properly i dont already have the injectors but it is something i am interested in will i need to get a larger throttle body or different intake manifold to get the proper air fuel mixture?
Old Feb 5, 2006 | 10:42 AM
TurboCoop's Avatar
make sure you search before you use them
Old Feb 5, 2006 | 10:43 AM
specscow's Avatar
Default Re: DSM 450cc injectors (TurboCoop)
what do you mean search?
Old Feb 5, 2006 | 10:53 AM
im selling my 450's if you want to buy them let me know
Old Feb 5, 2006 | 10:57 AM
specscow's Avatar
if i did just the injectors would the car run rich?
Old Feb 5, 2006 | 11:06 AM
btleier's Avatar
you need a resistor box too for them to work on a honda...
Old Feb 5, 2006 | 11:10 AM
97_delsol_Vtec's Avatar
yes u will need someone to wire them up for you. unless you know how to yourself.
specscow's Avatar
Default Re: (btleier)
what is a register box and where can i get one?
thanks
Old Feb 5, 2006 | 11:22 AM
specscow's Avatar
Default Re: (specscow)
any one know where i can get one of these register boxes and will the car need a new throttle body or anything to get more air to have the proper air fuel mixture?
Old Feb 5, 2006 | 11:32 AM
are you interested in buying mine?
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specscow &raquo;</TD></TR><TR><TD CLASS="quote">any one know where i can get one of these register boxes and will the car need a new throttle body or anything to get more air to have the proper air fuel mixture?</TD></TR></TABLE>
You'll need DSM 450s... and a Resistor box from an obd0 honda or you can buy inline resistors from Radioshack... you are going to have to do Homework for this part.
You will need something to TUNE the car with... at Minimum... a safc/vafc. Ideally you run a chipped ecu and tune with Crome or Uberdata... or some Pay to play platform.
You CANNOT just put these on your car and expect it to run right.... its pushing many many times more fuel into your motor.... it neeeeeeds to be controlled.
Old Feb 5, 2006 | 11:37 AM
specscow's Avatar
Default Re: (splitime)
thanks man that really helps me its a little more difficult then i had expected it to be thank you for the helpful information.
Old Feb 5, 2006 | 11:41 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specscow &raquo;</TD></TR><TR><TD CLASS="quote">thanks man that really helps me its a little more difficult then i had expected it to be thank you for the helpful information.</TD></TR></TABLE>
NP, it just sounds like you are thinking of them as a plug/play option... and they definitly are not
Old Feb 5, 2006 | 12:14 PM
specscow's Avatar
i was hoping for plug and play but i knew that it was too god to be true
Old Feb 5, 2006 | 12:21 PM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specscow &raquo;</TD></TR><TR><TD CLASS="quote">i was hoping for plug and play but i knew that it was too god to be true</TD></TR></TABLE>
Why are you looking at them btw? You mention "stock" 94 dx? You don't seem to have need for big injectors. Heck stockers are fine upto almost 200hp....
What are your goals and current setup?
Old Feb 5, 2006 | 01:46 PM
tallyturbo's Avatar
https://honda-tech.com/zerothread?id=1263795 go there and scrool down until it starts talking about injectors
Old Feb 5, 2006 | 02:04 PM
specscow's Avatar
i was just wondering i dont have any real expectations i just am trying to make it somewhat quick
Old Feb 5, 2006 | 03:01 PM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specscow &raquo;</TD></TR><TR><TD CLASS="quote">i was just wondering i dont have any real expectations i just am trying to make it somewhat quick</TD></TR></TABLE>
Okie, well just a heads up... if the motor setup is fairly stock... adding fuel won't really do anything other than drop your gas mileage... UNLESS you have other modifications that want some more fuel and even then... unless its Turbo... the stock injectors will do fine with a good tune.
Keangdawizes
Oct 31, 2008 11:56 PM
b16hatche
Oct 24, 2005 08:03 PM
BlackB18CTeg
Apr 2, 2003 07:40 AM
ridnmyhonda
Mar 18, 2003 06:24 AM
boostin b16
Jan 19, 2003 08:27 PM
