Drive to tunner with huge injectors?
When i finish the install on my turbo setup, will there be any way for me to get to the tunner, to get my aem ems tunned?
ill be running 720cc injectors wich would be to big for stock ecu and all to run.
or am i gona have to find a way to get this thing trailored?
You could probably get a temp FMU setup and drive it easy with stock injectors till you get where your going. How far you gotta go? Either that or leave the stock injectors and open the wastegate all the way and drive with stock ecu.
Where are you going for tuning? You can always upload a base map similar to your setup. Let me know what shop you are heading out to. I'll tell you if it's a good idea or not to drive over there. I totally recommend Benson Wong of Garage Kwai. He is incredible with the AEM EMS and has a lot of experience. My car was tuned by him and runs great.
its about an hour drive
could i drive there on stock injectors?
i have a sc61, b18b, built head/block. sst manifold. yada yada.....
my wastegate spring is like 7psi i think.
just figure out some rough values for the AEM building off the basemap just get some basic stuff for as many RPM's as you're going to need to turn. Fiddle around with it for an hour and it's easy to get the hang of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCX »</TD></TR><TR><TD CLASS="quote">Where are you going for tuning? You can always upload a base map similar to your setup. Let me know what shop you are heading out to. I'll tell you if it's a good idea or not to drive over there. I totally recommend Benson Wong of Garage Kwai. He is incredible with the AEM EMS and has a lot of experience. My car was tuned by him and runs great.</TD></TR></TABLE>
he is most likley gona be the guy tunning it. my work is gona be done at a shop near gurnee (speedquest).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NyQuiL »</TD></TR><TR><TD CLASS="quote">its about an hour drive
my wastegate spring is like 7psi i think.</TD></TR></TABLE>
Run on stock injectors using what? The stock computer or the AEM EMS? If you are using the AEM EMS you still need to upload a base map.
