Drag --> Inline Pro
Old Jul 19, 2002 | 08:45 AM
philo's Avatar
Default Drag --> Inline Pro
Has anyone replaced a Drag mani with an Inline Pro unit. I wanted to know if it moves the turbo closer or further away from the block.
I know it repositions the turbo so the DP needs reworking, but does the block need additional notching?
Old Jul 19, 2002 | 09:28 AM
Ri5e's Avatar
Default Re: Drag --> Inline Pro (philo)
It actually made my downpipe move up 2 inches or so, hitting the oil pan. Had to extend it down a little.
Old Jul 19, 2002 | 10:31 PM
philo's Avatar
Default Re: Drag --> Inline Pro (BG Boost)
But did it move the turbo closer to the block?
Old Jul 20, 2002 | 12:25 AM
PureTeg420's Avatar
The drag manifold is slightly angled, I don't think the inline pro manifold is. Which in that case would move the turbo 1/2" - 1" closer to the block
Old Jul 20, 2002 | 06:07 AM
XforgivenX's Avatar
New User
Default Re: Drag --> Inline Pro (PureTeg420)
The InlinePro manifold is slightly angled as well.
Old Jul 20, 2002 | 06:40 AM
falcongsr's Avatar
What is this crap?
Default Re: Drag --> Inline Pro (XforgivenX)
the turbine mounts directly below the manifold, but the flange for the turbine is off kilter so that the compressor housing faces away from the block slightly...should not require more block grinding.
civicb18Tkid
Mar 16, 2007 11:13 AM
Muckman
Jan 16, 2004 09:31 AM
chris@cfranklins
Jan 1, 2003 04:35 PM
DRAGLS
Oct 14, 2002 06:30 PM
AllMotorITR
Nov 30, 2001 09:20 AM
