Drag gen 3 question...
Old Jun 11, 2002 | 05:23 PM
R-1303's Avatar
Default Drag gen 3 question...
On the back of my tial..i put the vacumm hose to read manifold pressure..is that correct..because i heard your suppose to drill into the turbo and tap it to read that turbo vacumm on the compressor housing....i've seen that on the gen 2 kits but is gen 3 not supposed to do that?? info plz!! thanks
Old Jun 11, 2002 | 05:38 PM
R-1303's Avatar
Default Re: Drag gen 3 question... (R-1303)
I know i must be crazy..but i'm talking about that bung that comes of the turbo on the compressor side..on the gen 2 kits the plug it back into the wastegate..but on my gen 3 i don't have that bung so i plug the wate gate back to read manifold pressure around the fuel pressure regulator.
Old Jun 11, 2002 | 06:39 PM
LEON's Avatar
You can do either, run a line from the turbo to the side port of the Tial wastegate or from a vac source such as the fpr to the side port of the Tial wastegate, both are fine.
Old Jun 11, 2002 | 11:54 PM
R-1303's Avatar
Default Re: Drag gen 3 question... (LEON)
[QUOTE]You can do either, run a line from the turbo to the side port of the Tial wastegate or from a vac source such as the fpr to the side port of the Tial wastegate, both are fine.
Thanks!! i knew i did it right.. to you Leon
T25 civic
Jul 7, 2010 05:02 AM
Meet07
Mar 28, 2006 07:23 AM
GeorgeJetson
Jun 12, 2003 12:58 PM
spike
Dec 30, 2002 12:36 PM
civbeater90
Jan 8, 2002 02:39 PM
