DRAG 3 OWNERS!!!!! what the hell do i do?
Old Sep 28, 2001 | 06:07 PM
Mr. Vapor's Avatar
Default DRAG 3 OWNERS!!!!! what the hell do i do?
Ok on the exhaust manifold, the CENTER bolt on the lower half where the dip stick comes through.......HOW THE **** do i get that bolt in to mount the manifold to my head? i have shaved it down, and played with it for hours, and i am really fed up, what the hell? the bolt isnt even close to fitting in that tiny hole, the angle is way to steep......please help, please please
Old Sep 28, 2001 | 06:26 PM
DragII's Avatar
25 Year Member
Default Re: DRAG 3 OWNERS!!!!! what the hell do i do? (NYb16)
you just have to play with it....try loosening sum bolts, tightening others....it's a pain...but it will go on
Old Sep 28, 2001 | 06:38 PM
MackSpeed-616's Avatar
Default Re: DRAG 3 OWNERS!!!!! what the hell do i do? (DragIIcivic)
i replaced that particular bolt with a stud... its much easier to put a nut on it than to try to get a bolt in there.
Old Sep 28, 2001 | 07:44 PM
Mr. Vapor's Avatar
Default Re: DRAG 3 OWNERS!!!!! what the hell do i do? (TurboR616)
Next question, i found that the stock downpipe that comes with the Drag kit didnt line up perfectly for me, its pointing slightly towards the passanger side and angled up......does this mean my turbo is not lined up properly or is this beacuse the DP isnt right? i am going to the muffler shop tommrow so tell me what to do!
Old Sep 28, 2001 | 09:04 PM
sgT's Avatar
sgT
its the downpipe.
I always straighten them out when i install them.
Old Sep 28, 2001 | 09:07 PM
nutsack's Avatar
Default Re: DRAG 3 OWNERS!!!!! what the hell do i do? (sgT)
i couldn't get that center bolt in also so i just left it off. no problems so far. as for the downpipe any muffler shop can fix that for you.
Old Sep 28, 2001 | 09:26 PM
Mr. Vapor's Avatar
Default Re: DRAG 3 OWNERS!!!!! what the hell do i do? (*******)
ok PHEW! what a relief! i was all worried, i will just have them bend my downpipe a little then i will be in business! rock on fellas! thanks for the help, just another reason why i love this place
a side note: i know i am not Worthy yet, but now that i will be boosted, how do i go about becoming a "turbo mafia?" do i start low in the ranks.....say: "Turbo Infantry?" "turbo 1st platoon"
Old Sep 29, 2001 | 12:36 PM
Mr. Vapor's Avatar
update: SUCCESS IS MINE! id like to thank John at my Midas shop for helping fix my downpipe to fit!
Next question: could someone be a little more specific about what to do once i have put the pipe in my oil pan....i get lost here
Old Sep 29, 2001 | 01:29 PM
92CivicSiR's Avatar
New User
Put the pipe in the oil pan? I assume that you are talking about the drain plug. If that is it, then you need to connect it to the drain side on your turbo.
Old Sep 29, 2001 | 02:12 PM
Mr. Vapor's Avatar
Default Re: DRAG 3 OWNERS!!!!! what the hell do i do? (92CivicSiR)
no no, i mean where exactly should the pipe be entering the pan......i have it going in at a very shallow point in the pan, is this correct? anyone have pics?
Old Sep 29, 2001 | 03:32 PM
Mr. Vapor's Avatar
Todays question:
when plugging my fuel pump positive wire to the grey box that "clicks" when you turn your car on, it inserts to Pin #4, where exactly is this box under my dash? i cant turn it on cause i have no intake or exhaust manifold, and my fuel lines are in pieces!
Old Sep 29, 2001 | 06:16 PM
maxim's Avatar
Todays question:
I would like to know this too? It's been a while since someone posted to this topic. Have you figured it out yet NYb? What did you do - for my info?
Old Sep 30, 2001 | 10:28 AM
Mr. Vapor's Avatar
Default Re: DRAG 3 OWNERS!!!!! what the hell do i do? (maxim_force)
yea Maxim.....the grey box is right above the ECU, its actually not grey. put your ear down there when you turn your battery on, you can find it.
jacob4lester
Feb 16, 2010 09:31 PM
tegh22a
Aug 26, 2005 09:22 AM
boostincoupe
Jul 26, 2005 03:52 PM
Rod.
Jun 3, 2004 07:36 PM
