Down pipe help
Old Jun 9, 2004 | 04:49 PM
Boosted Chemist's Avatar
Default Down pipe help
Ok i got my turbo (t3/t4) on my inline manifold in my CRX mounted with the compressor on the driver side. Does anyone have pics of there down pipe mounted this way so i can get some ideas on how to fab mine. It looks a bit confusing because the exhaust outlet is cocked to the front instead of parallel to the motor.
any ideas/ pics is
Old Jun 9, 2004 | 05:47 PM
dunkd's Avatar
i dont get what u mean the exhaust side of the turbo cocked to the front? then the compressor side would be facing the block... how is that possible
my turbo is the same way (compressor on the driverside)... this makes it easier to fab a downpipe bc it comes straight down and under the oil pan... no turns to worry about.
Old Jun 9, 2004 | 06:49 PM
Default Re: (2 point ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 point ferio &raquo;</TD></TR><TR><TD CLASS="quote">i dont get what u mean the exhaust side of the turbo cocked to the front? then the compressor side would be facing the block... how is that possible
my turbo is the same way (compressor on the driverside)... this makes it easier to fab a downpipe bc it comes straight down and under the oil pan... no turns to worry about.</TD></TR></TABLE>
no instead of the compressor facing the side its cocked a couple of degrees forward, like 20 degrees
Old Jun 10, 2004 | 02:04 AM
Default Re: Down pipe help (Mad Chemist)
ne one has pics or ideas?
Old Jun 10, 2004 | 02:16 AM
project dc2's Avatar
u got a 5 bolt turbo or 4 bolt? if its a 5 bolt i have a dP in stock if 4 bolt i can make u onefor 185 for 2.5
Old Jun 10, 2004 | 04:41 AM
dunkd's Avatar
just buy the flange for $15... then buy some piping for about $40... then buy a piece of that steel braided flex for $20.... and make your own downpipe - that is the best way to do it to ensure that it will fit just right.
Buying something premade for a CUSTOM application never seems to work right.... unless somebody has the same manifold, turbo, motor and car as you...
Old Jun 10, 2004 | 01:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 point ferio &raquo;</TD></TR><TR><TD CLASS="quote">just buy the flange for $15... then buy some piping for about $40... then buy a piece of that steel braided flex for $20.... and make your own downpipe - that is the best way to do it to ensure that it will fit just right.
Buying something premade for a CUSTOM application never seems to work right.... unless somebody has the same manifold, turbo, motor and car as you...</TD></TR></TABLE>
i got the flange i wanna see peoples bends so i can get some ideas for mine, flex na im going ss 3"
come on nobody has any pics?
Old Jun 10, 2004 | 02:50 PM
i usually h ave the manifold/turbo and motor to base it off of.
Old Jun 10, 2004 | 06:36 PM
5thgen's Avatar
this was done using 2 3" ubends....i would have had more room without the vband, and i had to move the radiator right up against the radiator support. Everything has been working fine.
nokehockey20
Jun 2, 2016 12:35 PM
turbotime
Oct 31, 2005 02:41 PM
hondaguyexsi
Aug 7, 2005 06:41 PM
lazydude-t
Mar 18, 2005 07:26 PM
Ri5e
Apr 25, 2002 11:22 PM
