?!?!? Cracked Exhuast housing on Tubonetics t3/t4 ?!?!
Is that a f*cking crack on the exhuast housing of my turbo?!? This turbo is brand new- wtf is going on?
Is it just me or does that look like a crack?
Re: ?!?!? Cracked Exhuast housing on Tubonetics t3/t4 ?!?! (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">
Is it just me or does that look like a crack?</TD></TR></TABLE>
Do you have a flex pipe on your downpipe?
Re: (turbotime)
Thats prolly why. Without the flexpipe the downpipe has no play in it. When the engine torques the manifold and turbo move in the same direction as the engine. However, since you don't have a flexpipe the downpipe fights to move with the manifold and turbo. Get a flexpipe on there and that should help.
will this crack have a big effect on my performance? I mean do you think exhaust can leak thru there? What the fix? A new exhaust housing?
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">will this crack have a big effect on my performance? I mean do you think exhaust can leak thru there? What the fix? A new exhaust housing?</TD></TR></TABLE>
Personally I would just get a new exhaust housing. Cast iron can be welded but it takes a different process then welding steel. Get a price quote on a new exhaust housing and also to repair it. If its not that much of a difference just get a new housing. Goodluck.
im still building boost fine, or so it seems, im running 8.7 psi and it spools up seemingly fine.
How much do new housing run ?
Re: ?!?!? Cracked Exhuast housing on Tubonetics t3/t4 ?!?! (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">u sure thats a crack and not water stains from water seeping out between the flagne ? </TD></TR></TABLE>
nah im not sure thats why i was asking, you think that might be it, that would be better
Who is Mr Robot?
thats just a stain.... the same **** is on the dp flange and trust me, the downpipe will crack long before your turbine housing ever will
Re: ?!?!? Cracked Exhuast housing on Tubonetics t3/t4 ?!?! (wantboost)
knock it down with a wire brush or wheel; if its a water stain it'll go away if not a big ugly crack will show up.
for that type of a crack to show up right there that would have to be a crazy coincidence and a major manufacturing defect.
yeah thats what im saying if its a crack thats gotta be a defect, i mean i have no flex tube but theres no way it puts that much stress on the housing...
Im gonna go hit it with a wire brush and see what i turn up...
seems to me like it might just be a stain.
check out your dp flange, you have some on there as well.
just a thought. goodluck
EDIT: it is best though if you do get a piece of flexpipe to aid when the motor does torque, you wouldn't want anything to break in the long run. as stated above, it puts an immense amount of stress on dp/turbine housing when the motor rocks.
Modified by large farva at 4:21 PM 10/31/2005
well i went out after she cooled down and tried to wipe off the mark.
It isnt a crack but I dont think its a water stain. It looks like a welded seam kinda, weird, but its a raised line like a seam but not an indented line like a crack.
TheIntegraGuy
08-09-2005 11:00 AM
