down pipe drama
Old May 18, 2015 | 05:02 PM
cleansi's Avatar
Default down pipe drama
Suggestions, comments, and advice please
Some of you will probably just tell me to buy a new down pipe.
I'm open to any thing first. Thinking about wrapping it but it is right on top of the radiator. I could try and cut and weld at another angle. But I'm thinking even if I move the down pipe cut and reweld it doesn't look like even a slim fan will fit.
Old May 18, 2015 | 06:34 PM
DA-NINE's Avatar
Default Re: down pipe drama
Could you try a high cfm pusher fan mounted in front of the radiator with a wrapped downpipe.
Old May 18, 2015 | 06:55 PM
cleansi's Avatar
hmmm did not think about that...
honestly that sounds like a great idea, considering my options. will deff keep a eye on the temps but i think that could work.
after reevaluating the dp there is just no where to route a 4" but up and i cannot drive it with the copas around here like that.
my only other option i could think of would be to get a slim/tucked rad or cut my rad support.
Old May 18, 2015 | 07:05 PM
turbohatch96y7's Avatar
I run a spal pusher. Keeps temps stupid cold
Old May 18, 2015 | 07:06 PM
You could cut that center line radius on the down pipe down a lot
Looks like it has a 5" clr.
Old May 18, 2015 | 07:26 PM
DA-NINE's Avatar
from what I learned, upipes suck for 2 reasons.
1.people will drop things in them right into your turbine wheel/housing.
2. Rain-self explanitory
Just general gravity based things.
what size radiator are you running?
Old May 19, 2015 | 01:56 AM
Balor_Gr's Avatar
You could rotate the radiator a little bit to the right(clockwise as we see on the first picture)
Ive seen it done many times
Old May 19, 2015 | 03:41 AM
KevinEF7's Avatar
Pusher fan and a bottle of water wetter
If that downpipe is ceramic coated I wouldnt even wrap it, looks sick as is
Old May 19, 2015 | 04:53 AM
Same as yours
13" fan fit perfect but in an ek chassis
Old May 19, 2015 | 08:08 AM
LightningTeg's Avatar
Community Builder
Dont see why the downpipe needs such a huge radius.
goatzee
Feb 18, 2006 08:52 PM
JFG Kevin
16
Feb 4, 2006 02:11 PM
handa
Jun 21, 2004 06:34 PM
Boosted Chemist
Jun 17, 2004 05:16 AM
miketurbohonda
May 5, 2004 01:51 AM
